Author Topic: [SOLVED] Unable to find root device  (Read 24026 times)
Offline SeZo
Re: [SOLVED] Unable to find root device
« Reply #15 on: June 05, 2012, 02:05:07 pm »
I've just got back from a course and powered my PC up.  After the GRUB menu it start loading up then suddenly;
Glad you got it sorted. :D
The "pacman-key --init" bit seems strange. Did you update pacman before you went away?
@BkS
This is why I stay firmly in my roots with Nautilus... XD
pacman is to Arch what apt is for Ubuntu (or any other Debian based distro) ;D
« Last Edit: June 05, 2012, 02:23:23 pm by SeZo »
Offline glitch
  • digital jedi
  • Sr. Member
  • age of the geek!
« Reply #16 on: June 05, 2012, 03:25:34 pm »
Yeah I update almost every other day.  Everything was working fine.
I think it might have something to do with having the hard drive mounted via a live distro.
//glitch
END OF LINE_
@g1i7ch
