Author Topic: SOLVED XSane startup  (Read 11529 times)
Offline donwatson
  • Getting older
« on: June 04, 2012, 11:21:10 pm »
Hi Folks,
I am back with another problem.
When I try to use XSane to scan it comes up with the error message ;
Error during CMS conversion:
Could not open scanner ICM profile:
Where do I find the ICM profile ?
take care
Don W
« Last Edit: June 05, 2012, 01:07:58 am by donwatson »
Novatech build
External 2TiB HD
Re: XSane startup
« Reply #1 on: June 05, 2012, 12:18:49 am »
I take it Xsane still starts/works ?
If so (and you don't use colour profiling) .. have you tried unchecking Preferences > Enable colour management
If you do use colour profiling, see here:
http://www.xsane.org/doc/sane-xsane-setup-color-management-doc.html
and maybe:
http://ubuntuforums.org/showthread.php?t=870424
« Last Edit: June 05, 2012, 01:23:47 am by Mark Greaves (PCNetSpec) »
Re: XSane startup
Offline donwatson
  • Getting older
Re: XSane startup
« Reply #2 on: June 05, 2012, 01:06:31 am »
Thanks Mark,
I unchecked Preferences>Enable colour management and it now works.
take care
Don w
Novatech build
External 2TiB HD
