Author Topic: touchpad doesent work in peppermint os acer aspire one aoa150 -bb  (Read 4924 times)
Offline uglyjohny
Hello ppl,
as the tittle say my touchpad dont work in peppermint os.
It did worked coz i had pepp2 installed but i wanted to try osx
and when i reinstalled it again no touchpad and no left and right button.
wht i have tried> 1. Fn+F7 (nothing, every other funktion work)
johny@acer ~ $ xinput --list
⎡ Virtual core pointer                       id=2   [master pointer  (3)]
⎜   â†³ Virtual core XTEST pointer                 id=4   [slave  pointer  (2)]
⎣ Virtual core keyboard                      id=3   [master keyboard (2)]
    ↳ Virtual core XTEST keyboard                id=5   [slave  keyboard (3)]
    ↳ Power Button                               id=6   [slave  keyboard (3)]
    ↳ Video Bus                                  id=7   [slave  keyboard (3)]
    ↳ Power Button                               id=8   [slave  keyboard (3)]
    ↳ Sleep Button                               id=9   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard               id=10   [slave  keyboard (3)]
    ↳ USB 2.0 Camera                             id=12   [slave  keyboard (3)]
johny@acer ~ $ lsusb
Bus 001 Device 003: ID 0c45:62c0 Microdia Sonix USB 2.0 Camera
johny@acer ~ $ sudo modprobe -r psmouse && sudo modprobe psmouse
tried  even some scprits to enable touchpad after using keyboard
and checked is touchpad on menu options
untill monday i cant check is this hardware failure so any further help is wellcome
thanks
Re: touchpad doesent work in peppermint os acer aspire one aoa150 -bb
« Reply #1 on: July 21, 2012, 01:04:38 pm »
Looking at the assigned "id"numbers from xinput .. I'm going to guess the touchpad is being given id=11 but is then disconnected for some reason.
Can you run:
dmesg | grep syn
and post any output.
if there is NO output, run:
dmesg > ~/dmesg.txt
You'll then find a file called dmesg.txt in you Home directory .. attach that to the next posting.
Offline uglyjohny
« Reply #2 on: July 21, 2012, 02:07:44 pm »
ok, this is wht i got.
« Reply #3 on: July 21, 2012, 04:44:39 pm »
Hmm .. doesn't seem to be being detected at all ???
Have you tried it from a LiveUSB ? .. just to rule out the install ?
May sound daft, but have you also tried (whilst the AA1 is switched OFF) removing both the battery and power lead .. then hitting the power switch to discharge the motherboard capacitors .. then reconnecting the battery and power lead, and booting ?
Have you recently taken the AA1 apart ?
Though this shouldn't be necessary for the touchpad to work .. have you run a system update ?
« Last Edit: July 21, 2012, 04:53:29 pm by Mark Greaves (PCNetSpec) »
Offline uglyjohny
« Reply #4 on: July 21, 2012, 05:04:39 pm »
yes, i tried from diferent live distro to boot up... it could be hw failure cos i changed wireles adapter on my acer ... thanks anyway
ill use usb mouse till i take it to the repair shop and post some updates on this
« Reply #5 on: July 21, 2012, 05:12:37 pm »
If you've had it apart, there's a chance you've not seated the ribbon cable from the motherboard to the touchpad correctly .. that happened to me once .. took it apart t add more RAM, when I put it back together it "looked" OK, but the touchpad didn't work .. disconnected and reconnected, and it worked perfectly.
Good luck :)
« Last Edit: July 21, 2012, 05:16:03 pm by Mark Greaves (PCNetSpec) »
Offline uglyjohny
« Reply #6 on: July 21, 2012, 05:17:38 pm »
thanks, ill take it apart again :)))
« Reply #7 on: July 21, 2012, 05:55:22 pm »
If you're comfortable taking it apart again .. it's certainly worth a shot :)
The second time .. it tested it before clicking the keyboard back in place .. as IMHO the keyboard is the only fiddly bit.
Good luck.
« Last Edit: July 21, 2012, 05:57:54 pm by Mark Greaves (PCNetSpec) »
