Author Topic: Tutorial - Installing PeppermintOS Three on an Acer Aspire One AOA110L ZG5  (Read 82806 times)
Re: Tutorial - Installing PeppermintOS Three on an Acer Aspire One AOA110L ZG5
« Reply #135 on: February 12, 2013, 01:02:12 am »
On an Acer Aspire One ?
If you followed stage 9 (on an AA1):
http://linuxforums.org.uk/index.php?topic=10313.msg76522#msg76522
your mic should be working ???
« Last Edit: February 12, 2013, 01:04:50 am by Mark Greaves (PCNetSpec) »
Offline mako6
  • Full Member
« Reply #136 on: February 12, 2013, 10:31:26 pm »
No, internal mike is dead as a doornail, though I've never seen a live one. Tried external mike on it BTW and got horrible distortion till I reduced those volume levels you specified. What worked for me was 32-100% mike boost, 37% capture (both sides, since it is stereo jack, and audiocity wants other side too), 66-77% digital. The mike boost would crazily autoset to 100% when Skype connected to a (test) call, and then had no other setting but 32% or 0, very strange. With 32% it was quite clear, 100% had a bit of distortion but manageable if the capture was turned down.
The on-board mike may be much less sensitive. It initially didn't work for over 1 year, then some update to Skype or benevolent spirits fixed it?
Re: the fan running all the time- I fixed that too, but it isn't necessary to enter commands for temp. If people installed Jupiter, the core temp is at the top when you click on it.
I noticed Cheese had alot of Gnome dependencies including Nautilus- we should prefer KDE programs rather than Gnome for size and efficiency, right?
« Reply #137 on: February 13, 2013, 01:06:57 am »
Most definitely NOT .. KDE apps will pull in more dependencies than Gnome apps .. but for now DO NOT install cheese, as you say the new version has nautilus as a dependency which may break Peppermint .. leave it with me for a few days and I'll see if it's possible to remove that dependency.
Meanwhile, you could try guvcview .. it doesn't work on my AA1 but my Peppermint install is now heavily modified.
Did you take the tick OUT of "Allow Skype to autiatically adjust my mixer levels" ?
in Skype is the Microphone sound device set to "PulseAudio server (local)" ?
« Reply #138 on: February 13, 2013, 06:44:01 pm »
OK, anyone that wants cheese in Peppermint 3 .. install it with the --no-install-recommends option .. as one of the recommends is nautilus, and you don't want that.
So to install cheese, open a terminal and run:
sudo apt-get install --no-install-recommends cheese
Offline smogreg
« Reply #139 on: February 13, 2013, 10:38:37 pm »
Hello Mark. Although everything seems to be running OK with Peppermint Three on my Acer, when I try to install the recommended updates I get error messages such as the following :
"debconf: unable to initialize frontend: Gnome
debconf: (Unable to load Gtk -- is libgtk2-perl installed?)
debconf: falling back to frontend: Dialog
(Reading database ... 132255 files and directories currently installed.)
Preparing to replace libpciaccess0 0.12.902-1 (using .../libpciaccess0_0.12.902-1ubuntu0.1_i386.deb) ...
Unpacking replacement libpciaccess0 ...
Setting up grub-pc (1.99-21ubuntu3.9) ...
/var/lib/dpkg/info/grub-pc.config: 35: /etc/default/grub: Syntax error: EOF in backquote substitution
dpkg: error processing grub-pc (--configure):
 subprocess installed post-installation script returned error exit status 2
No apport report written because MaxReports is reached already
                                                              Setting up libpciaccess0 (0.12.902-1ubuntu0.1) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
 grub-pc
W: Waited for dpkg --assert-multi-arch but it wasn't there - dpkgGo (10: No child processes)
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
 grub-pc"
Any ideas what to do next ?
Many thanks in anticipation....
« Reply #140 on: February 13, 2013, 11:15:36 pm »
Try running:
sudo apt-get install --reinstall libgtk2-perl
sudo apt-get install -f
sudo apt-get clean
sudo apt-get upgrade
Do you get any errors .. if so, can you post them.
Offline smogreg
« Reply #141 on: February 14, 2013, 12:07:36 am »
I did as you requested, and got the following :
"[email protected] ~ $ sudo apt-get install --reinstall libgtk2-perl
[sudo] password for greg:
Reading package lists... Done
Building dependency tree
  libcairo-perl libglib-perl libpango-perl
Suggested packages:
  libfont-freetype-perl libgtk2-perl-doc
The following NEW packages will be installed:
  libcairo-perl libglib-perl libgtk2-perl libpango-perl
0 upgraded, 4 newly installed, 0 to remove and 6 not upgraded.
1 not fully installed or removed.
Need to get 1,597 kB of archives.
After this operation, 5,134 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://au.archive.ubuntu.com/ubuntu/ precise/main libcairo-perl i386 1.081-1build2 [121 kB]
Get:2 http://au.archive.ubuntu.com/ubuntu/ precise/main libglib-perl i386 2:1.241-1 [389 kB]
Get:3 http://au.archive.ubuntu.com/ubuntu/ precise/main libpango-perl i386 1.222-1build1 [221 kB]
Get:4 http://au.archive.ubuntu.com/ubuntu/ precise/main libgtk2-perl i386 2:1.223-1build3 [865 kB]
Fetched 1,597 kB in 10s (151 kB/s)
Selecting previously unselected package libcairo-perl.
Unpacking libcairo-perl (from .../libcairo-perl_1.081-1build2_i386.deb) ...
Selecting previously unselected package libglib-perl.
Unpacking libglib-perl (from .../libglib-perl_2%3a1.241-1_i386.deb) ...
Selecting previously unselected package libpango-perl.
Unpacking libpango-perl (from .../libpango-perl_1.222-1build1_i386.deb) ...
Selecting previously unselected package libgtk2-perl.
Unpacking libgtk2-perl (from .../libgtk2-perl_2%3a1.223-1build3_i386.deb) ...
Processing triggers for man-db ...
Setting up libcairo-perl (1.081-1build2) ...
                                                              Setting up libglib-perl (2:1.241-1) ...
Setting up libpango-perl (1.222-1build1) ...
Setting up libgtk2-perl (2:1.223-1build3) ...
 grub-pc
[email protected] ~ $ sudo apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
After this operation, 0 B of additional disk space will be used.
 grub-pc
[email protected] ~ $ sudo apt-get clean
[email protected] ~ $ sudo apt-get update
Ign http://au.archive.ubuntu.com precise InRelease
Ign http://au.archive.ubuntu.com precise-updates InRelease
Ign http://au.archive.ubuntu.com precise-backports InRelease
Hit http://au.archive.ubuntu.com precise Release.gpg
Get:1 http://au.archive.ubuntu.com precise-updates Release.gpg [198 B]
Get:2 http://au.archive.ubuntu.com precise-backports Release.gpg [198 B]
Get:3 http://au.archive.ubuntu.com precise-updates Release [49.6 kB]
Get:4 http://au.archive.ubuntu.com precise-backports Release [49.6 kB]
Ign http://archive.canonical.com precise InRelease
Ign http://extras.ubuntu.com precise InRelease
Ign http://security.ubuntu.com precise-security InRelease
Ign http://ppa.launchpad.net precise InRelease
Hit http://au.archive.ubuntu.com precise/main Sources
Hit http://au.archive.ubuntu.com precise/restricted Sources
Hit http://au.archive.ubuntu.com precise/universe Sources
Hit http://au.archive.ubuntu.com precise/multiverse Sources
Hit http://au.archive.ubuntu.com precise/main i386 Packages
Hit http://au.archive.ubuntu.com precise/restricted i386 Packages
Hit http://au.archive.ubuntu.com precise/universe i386 Packages
Hit http://au.archive.ubuntu.com precise/multiverse i386 Packages
Hit http://au.archive.ubuntu.com precise/main TranslationIndex
Hit http://au.archive.ubuntu.com precise/multiverse TranslationIndex
Hit http://au.archive.ubuntu.com precise/restricted TranslationIndex
Hit http://au.archive.ubuntu.com precise/universe TranslationIndex
Get:5 http://au.archive.ubuntu.com precise-updates/main Sources [367 kB]
Hit http://archive.canonical.com precise Release.gpg
Hit http://extras.ubuntu.com precise Release.gpg
Hit http://ppa.launchpad.net precise Release.gpg
Get:6 http://security.ubuntu.com precise-security Release.gpg [198 B]
Get:7 http://security.ubuntu.com precise-security Release [49.6 kB]
Hit http://archive.canonical.com precise/partner Sources
Hit http://extras.ubuntu.com precise/main Sources
Hit http://archive.canonical.com precise/partner i386 Packages
Ign http://archive.canonical.com precise/partner TranslationIndex
Hit http://extras.ubuntu.com precise/main i386 Packages
Ign http://extras.ubuntu.com precise/main TranslationIndex
Hit http://ppa.launchpad.net precise/main Sources
Hit http://ppa.launchpad.net precise/main i386 Packages
Ign http://ppa.launchpad.net precise/main TranslationIndex
Get:8 http://au.archive.ubuntu.com precise-updates/restricted Sources [5,135 B]
Get:9 http://au.archive.ubuntu.com precise-updates/universe Sources [78.6 kB]
Get:10 http://security.ubuntu.com precise-security/main Sources [63.1 kB]
Get:11 http://au.archive.ubuntu.com precise-updates/multiverse Sources [4,726 B]
Get:12 http://au.archive.ubuntu.com precise-updates/main i386 Packages [584 kB]
Get:13 http://security.ubuntu.com precise-security/restricted Sources [1,950 B]
Get:14 http://security.ubuntu.com precise-security/universe Sources [21.4 kB]
Ign http://archive.canonical.com precise/partner Translation-en_AU
Get:15 http://security.ubuntu.com precise-security/multiverse Sources [1,380 B]
Get:16 http://security.ubuntu.com precise-security/main i386 Packages [234 kB]
Ign http://extras.ubuntu.com precise/main Translation-en_AU
Ign http://ppa.launchpad.net precise/main Translation-en_AU
Get:17 http://security.ubuntu.com precise-security/restricted i386 Packages [3,968 B]
Get:18 http://security.ubuntu.com precise-security/universe i386 Packages [68.3 kB]
Get:19 http://security.ubuntu.com precise-security/multiverse i386 Packages [2,371 B]
Hit http://security.ubuntu.com precise-security/main TranslationIndex
Get:20 http://au.archive.ubuntu.com precise-updates/restricted i386 Packages [9,503 B]
Hit http://security.ubuntu.com precise-security/multiverse TranslationIndex
Hit http://security.ubuntu.com precise-security/restricted TranslationIndex
Hit http://security.ubuntu.com precise-security/universe TranslationIndex
Get:21 http://au.archive.ubuntu.com precise-updates/universe i386 Packages [181 kB]
Hit http://security.ubuntu.com precise-security/main Translation-en
Hit http://security.ubuntu.com precise-security/multiverse Translation-en
Hit http://security.ubuntu.com precise-security/restricted Translation-en
Get:22 http://au.archive.ubuntu.com precise-updates/multiverse i386 Packages [10.4 kB]
Hit http://au.archive.ubuntu.com precise-updates/main TranslationIndex
Hit http://au.archive.ubuntu.com precise-updates/multiverse TranslationIndex
Hit http://au.archive.ubuntu.com precise-updates/restricted TranslationIndex
Hit http://au.archive.ubuntu.com precise-updates/universe TranslationIndex
Get:23 http://au.archive.ubuntu.com precise-backports/main Sources [2,422 B]
Get:24 http://au.archive.ubuntu.com precise-backports/restricted Sources [14 B]
Get:25 http://au.archive.ubuntu.com precise-backports/universe Sources [21.8 kB]
Get:26 http://au.archive.ubuntu.com precise-backports/multiverse Sources [2,669 B]
Get:27 http://au.archive.ubuntu.com precise-backports/main i386 Packages [1,941 B]
Hit http://security.ubuntu.com precise-security/universe Translation-en
Get:28 http://au.archive.ubuntu.com precise-backports/restricted i386 Packages [14 B]
Get:29 http://au.archive.ubuntu.com precise-backports/universe i386 Packages [22.4 kB]
Get:30 http://au.archive.ubuntu.com precise-backports/multiverse i386 Packages [2,504 B]
Hit http://au.archive.ubuntu.com precise-backports/main TranslationIndex
Hit http://au.archive.ubuntu.com precise-backports/multiverse TranslationIndex
Hit http://au.archive.ubuntu.com precise-backports/restricted TranslationIndex
Hit http://au.archive.ubuntu.com precise-backports/universe TranslationIndex
Get:31 http://au.archive.ubuntu.com precise/main Translation-en_AU [4,434 B]
Hit http://au.archive.ubuntu.com precise/main Translation-en
Get:32 http://au.archive.ubuntu.com precise/multiverse Translation-en_AU [94.4 kB]
Hit http://au.archive.ubuntu.com precise/multiverse Translation-en
Get:33 http://au.archive.ubuntu.com precise/restricted Translation-en_AU [2,407 B]
Hit http://au.archive.ubuntu.com precise/restricted Translation-en
Hit http://au.archive.ubuntu.com precise/universe Translation-en
Get:34 http://au.archive.ubuntu.com precise-updates/main Translation-en_AU [4,434 B]
Hit http://au.archive.ubuntu.com precise-updates/main Translation-en
Get:35 http://au.archive.ubuntu.com precise-updates/multiverse Translation-en_AU [94.4 kB]
Hit http://au.archive.ubuntu.com precise-updates/multiverse Translation-en
Get:36 http://au.archive.ubuntu.com precise-updates/restricted Translation-en_AU [2,407 B]
Hit http://au.archive.ubuntu.com precise-updates/restricted Translation-en
Hit http://au.archive.ubuntu.com precise-updates/universe Translation-en
Hit http://au.archive.ubuntu.com precise-backports/main Translation-en
Hit http://au.archive.ubuntu.com precise-backports/multiverse Translation-en
Hit http://au.archive.ubuntu.com precise-backports/restricted Translation-en
Hit http://au.archive.ubuntu.com precise-backports/universe Translation-en
Fetched 2,042 kB in 14s (136 kB/s)
[email protected] ~ $ sudo apt-get upgrade
The following packages have been kept back:
  linux-generic linux-headers-generic linux-image-generic
The following packages will be upgraded:
  xserver-xorg-core xserver-xorg-video-intel xserver-xorg-video-qxl
3 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Need to get 1,981 kB of archives.
After this operation, 2,048 B of additional disk space will be used.
Get:1 http://au.archive.ubuntu.com/ubuntu/ precise-updates/main xserver-xorg-core i386 2:1.11.4-0ubuntu10.11 [1,675 kB]
Get:2 http://au.archive.ubuntu.com/ubuntu/ precise-updates/main xserver-xorg-video-intel i386 2:2.17.0-1ubuntu4.3 [240 kB]
Get:3 http://au.archive.ubuntu.com/ubuntu/ precise-updates/main xserver-xorg-video-qxl i386 0.0.16-2ubuntu0.1 [66.1 kB]
Fetched 1,981 kB in 13s (149 kB/s)
(Reading database ... 132535 files and directories currently installed.)
Preparing to replace xserver-xorg-core 2:1.11.4-0ubuntu10.8 (using .../xserver-xorg-core_2%3a1.11.4-0ubuntu10.11_i386.deb) ...
Unpacking replacement xserver-xorg-core ...
Preparing to replace xserver-xorg-video-intel 2:2.17.0-1ubuntu4.2 (using .../xserver-xorg-video-intel_2%3a2.17.0-1ubuntu4.3_i386.deb) ...
Unpacking replacement xserver-xorg-video-intel ...
Preparing to replace xserver-xorg-video-qxl 0.0.16-2 (using .../xserver-xorg-video-qxl_0.0.16-2ubuntu0.1_i386.deb) ...
Unpacking replacement xserver-xorg-video-qxl ...
Setting up xserver-xorg-core (2:1.11.4-0ubuntu10.11) ...
Setting up xserver-xorg-video-intel (2:2.17.0-1ubuntu4.3) ...
Setting up xserver-xorg-video-qxl (0.0.16-2ubuntu0.1) ...
 grub-pc
[email protected] ~ $ ""
« Reply #142 on: February 14, 2013, 12:38:22 am »
First make sure you have a Peppermint 3 LiveUSB .. just in case we need to reinstall grub after trying the things below.
First try this:
sudo dpkg-reconfigure grub-pc
If you still get errors, try this:
sudo apt-get remove --purge grub-pc
sudo apt-get install grub-pc
Any errors ?
« Last Edit: February 14, 2013, 12:41:55 am by Mark Greaves (PCNetSpec) »
Offline smogreg
« Reply #143 on: February 14, 2013, 10:57:33 am »
Sorry about the delay getting back to you, Mark.
 I used the Peppermint 3 LiveUSB after pasting your instructions. I found it nigh impossible to re-install Grub, so decided to cut my losses and do a TOTAL Peppermint re-install, including any updates. Although I saved the error messages to Libre Writer, the re-install has obviously overwritten them. I recall one error message stating that grub was broken or missing components or some such information.
When I tried to post to the forum I was prompted for a Google email ID and password, which I do not use ?? That's why I chose a complete re-install. As far as I can tell, the install has worked OK, but I shall see what happens when I attempt to download the next recommended updates. It may be that my LiveUSB was corrupted from the outset.
Should it recur, I will save the error messages to another USB and post them. So please don't think I have set out to waste your time. Your support is fully appreciated ! So maybe my previous two posts can be deleted until the situation arises again ? (And perhaps you prefer us punters to show the Terminal output as attachments to our posts?)
As an aside, Firefox as part of the PP3 installation does not seem to activate the "Search" box in the middle of the screen (under the Firefox logo). One has to use the 'Paste and Go' option at the top of the screen. Not crucial, but such a workaround is a bit messy.
Many thanks agaain.....
« Reply #144 on: February 14, 2013, 12:40:55 pm »
If you mean like this:-
Just set
about:startpage
as your homepage.
Or (in Firefox) go to Edit>Preferences>General (tab) .. then click the Home Page>Restore to Default button
Offline smogreg
« Reply #145 on: February 15, 2013, 12:12:30 am »
Thank you Mark, but perhaps I wasn't clear about Firefox not being operational after installing Peppermint Three.
 I get the screen you showed, but clicking on the BLUE search box in the middle of the screen does not activate any search. I have to revert to the Search Bar Address at the top of the screen to search. The Search Box in the middle of the screen remains dormant.
« Reply #146 on: February 15, 2013, 03:11:39 am »
My apologies (I was wrong about - about:startpage) .. do this:
In the Firefox address bar enter:
about:config
Hit enter.
Click the "I'll be careful, I promise!" button.
In the search field enter:-
mstone
Right-click the:-
browser.startup.homepage_override.mstone
entry, and select:-
Reset
Close ALL instances of Firefox .. and restart it.
Now in the Firefox address bar, enter:-
about:home
and hit Enter.
Does the search box/button work now ?
If so, set about:home as your homepage (if you wish).
Offline smogreg
« Reply #147 on: February 15, 2013, 04:23:05 am »
Magic ! Mark, you are a LEGEND ! Firefox Search Box works beautifully ! A thousand thanks again, old mate !
Offline waxi699
Hi mark
Am having problems installing peppermint os three on my Acer one running the old linpus os. I followed your steps of downloading the peppermint file then used the usb installer link. Step 1 is complete
I than plug the usb and turn on my acer and select f12 for boot options
I then select USB from three boot options
I then get a black screen with the message
SYSLINUX 4.03 2010-10-22 EDD Copyright (c) 1994-2010 H. Peter Anvin et al"
Please help..
Many thanks
Hi waxi699, and welcome to the forum :)
When you turn on your AA1, and hit F12 to select the USB stick .. is the USB stick listed as:-
USB HDD (Hard Disk Drive)
USB FDD (Floppy Disk Drive)
If it's listed as a FDD, chances are you'll have to use a different USB stick .. the AA1 can be a bit fussy about some USB sticks.
There's a *small* chance that a different LiveUSB creator application will work, but it's unlikely :(
There's also chance that turning the Peppermint ISO image into an isohybrid image, then using cat/dd to put it on the USB stick might work .. but you'd need a Linux PC to do this (not Linpus).
By far the easiest solution is a different USB stick.
« Last Edit: March 03, 2013, 07:38:54 pm by Mark Greaves (PCNetSpec) »
