Author Topic: Tutorial - Installing PeppermintOS Three on an Acer Aspire One AOA110L ZG5  (Read 81617 times)
Offline Karen S
  • Gender: Female
Re: Tutorial - Installing PeppermintOS Three on an Acer Aspire One AOA110L ZG5
« Reply #165 on: September 18, 2013, 12:00:03 pm »
Hi mark.
It's been 2 years since I started following your brilliant instructions to install Peppermint on my AOA 150, and then the fan fix which worked great.  This time, when I installed Peppermint 4 the fan started getting busy again. I followed your fan fix instructions but get an error when I enter: sudo modprobe acerhdf.  It says: ERROR: could not insert 'acerhdf': Invalid argument.  The temp check command does not work either.  It says: No such file or directory.  The fan is still running.  Any ideas please?
I hope this is the right place to post my question, or am I supposed to start a new topic?
Thanks.
Karen
« Reply #166 on: September 18, 2013, 12:11:38 pm »
Hi Karen .. there's a tutorial for Peppermint 4 here:
Tutorial - Installing PeppermintOS Four on an Acer Aspire One AOA110L ZG5
The acerhdf that's in the default repos for Peppermint 4 is broken .. but take a look at "Stage 10" for how to download/compile/install a fixed version under Peppermint 4.
There are also some other minor adjustments in the Peppermint 4 tutorial ;)
« Last Edit: September 18, 2013, 12:13:34 pm by Mark Greaves (PCNetSpec) »
Offline Karen S
  • Gender: Female
« Reply #167 on: September 18, 2013, 12:22:39 pm »
Hi Mark.
Thanks for getting back to me.  I am probably posting in the wrong place!
Looking at the link, it is the same as the Stage 10 I followed which is on the Peppermint OS forum posted Fri Aug 30 2013.  The errors I am getting are from following Stage 10.  What should I do now?
« Reply #168 on: September 18, 2013, 12:27:50 pm »
Gimme a sec, and I'll test them again.
« Reply #169 on: September 18, 2013, 12:36:35 pm »
OK seems to work fine for me ???
What kernel are you currently running .. what's the output from:
uname -a
Offline Karen S
  • Gender: Female
« Reply #170 on: September 18, 2013, 12:42:55 pm »
It says:
Linux user-AOA150 3.8.0-30-generic #44-Ubuntu SMP Thu Aug 22 20:54:42 UTC 2013 i686 i686 i686 GNU/Linux
« Last Edit: September 18, 2013, 12:55:16 pm by Mark Greaves (PCNetSpec) »
« Reply #172 on: September 18, 2013, 02:40:23 pm »
Problem solved in chat .. the issue was that:-
options acerhdf interval=5 fanon=60000 fanoff=55000 kernelmode=1
had been written to:-
/etc/modprobe.d/local.conf
multiple times
