Author Topic: [SOLVED] Export/Import to Thunderbird  (Read 4200 times)
Offline pooky2483
Re: Export/Import to Thunderbird
« Reply #15 on: August 03, 2012, 05:14:21 pm »
just entered your last command, now rebooting.
« Reply #16 on: August 03, 2012, 05:15:35 pm »
OK, run:
sudo killall thunderbird
sudo chown -Rv pooky2483:pooky2483 ~/.thunderbird
Then try starting Thunderbird, and tell me what happens.
This may not have worked if thunderbird was runnng .. we may have to start again .. let me know what happens when you restart thunderbird.
And you're getting ahead of me again .. where did I say reboot ?
« Last Edit: August 03, 2012, 05:18:10 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #17 on: August 03, 2012, 05:18:00 pm »
Entered last command, rebooted, now got this;
Offline pooky2483
« Reply #18 on: August 03, 2012, 05:18:48 pm »
Thunderbird started OK and I can see the e-mails.
Offline pooky2483
« Reply #19 on: August 03, 2012, 05:20:39 pm »
OK, run:
When I say last command, I mean the one before this one
« Reply #20 on: August 03, 2012, 05:26:07 pm »
If thunderbird is working .. create a new topic for the HPLIP service status error .. and mention which desktop environment you're running Unity/Gome/Gnome (classic) etc.
Also mention if that was the first reboot after installing hplip-gui
