Author Topic: [SOLVED] Xscreensaver Daemon not working  (Read 9481 times)
Re: Xscreensaver Daemon not working
« Reply #15 on: August 03, 2012, 06:42:04 pm »
And if you click OK ?
How many screens have you got attached ?
Offline pooky2483
« Reply #16 on: August 03, 2012, 06:44:19 pm »
I got this;
« Reply #17 on: August 03, 2012, 06:59:52 pm »
Is gnome-screensaver listed in your startup applications ?
Offline pooky2483
« Reply #18 on: August 03, 2012, 07:05:22 pm »
Yes, it is. Should it not be?
« Reply #19 on: August 03, 2012, 07:11:06 pm »
gnome-screensaver interferes with xscreensaver
You can either stop it from loading by disabling it in startup applicactions .. then add xscreensaver to startup applicatons
or uninstall it, and add xscreensaver to startup applications.
Be aware xscreensaver must be installed BEFORE uninstalling gnome-screensaver.
This video may help
« Last Edit: August 03, 2012, 08:17:08 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #20 on: August 03, 2012, 08:11:07 pm »
Installed ok, well - seems ok, no error popped up.
Should I have both screensavers in here...
« Last Edit: August 03, 2012, 08:16:22 pm by pooky2483 »
« Reply #21 on: August 03, 2012, 09:52:55 pm »
If xscreensaver is now working because you uninstalled gnome-screensaver .. leave it as is.
(that entry in startup applications could probably be removed, but it won't hurt to leave it either .. untick it if you want)
Oh, and if you consider the topic solved.....
Offline pooky2483
« Reply #22 on: August 04, 2012, 01:26:26 pm »
Sorry, I missed this one yesterday, I only have 1 screen attached.
