Author Topic: Make VLC the default media player for video and audio filetypes  (Read 3165 times)
« on: September 09, 2012, 02:06:31 pm »
To make VLC the default media player for *most* video and audio formats ..
(obviously you'll need to have VLC installed first)
First backup your current users ~/.local/share/applications/mimeapps.list by opening a terminal (Ctrl+Alt+T), and run:
cp -vf ~/.local/share/applications/mimeapps.list ~/.local/share/applications/mimeapps.list.backup
Ok now lets add the mimetypes for audio:
grep "^MimeType=" /usr/share/applications/vlc.desktop | cut -d "=" -f 2 | xargs -d ';' -n 1 | grep -e "^audio/" -e "^x-content/audio" | xargs -n 1 -I '{}' xdg-mime default vlc.desktop '{}'
and now for video:
grep "^MimeType=" /usr/share/applications/vlc.desktop | cut -d "=" -f 2 | xargs -d ';' -n 1 | grep -e "^video/" -e "^x-content/video" | xargs -n 1 -I '{}' xdg-mime default vlc.desktop '{}'
There may be a *few* filetypes that were missed, but those can be added in the normal way -
Right-click on the file, select "Open With", select VLC, and tick the box "Set as default".
But those commands will add all VLC's defaults (as gleaned from the vlc.desktop file) :)
If anything goes wrong .. you can undo this by running:
cp -vf ~/.local/share/applications/mimeapps.list.backup ~/.local/share/applications/mimeapps.list
« Last Edit: September 10, 2012, 11:43:22 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
Re: Make VLC the default media player for video and audio filetypes
« Reply #1 on: September 09, 2012, 04:20:40 pm »
Now this I can use!
Offline SeZo
« Reply #2 on: September 09, 2012, 05:30:00 pm »
Very nifty.
I would have gone straight to ~/.local/share/applications/mimeapps.list and manually edited it, but hey I am for simple solutions.
This is to go into my toolbox. ;)
