Author Topic: Ralink wireless card does not work [SOLVED]  (Read 158497 times)
Offline vishal
Re: Ralink wireless card does not work [SOLVED]
« Reply #150 on: October 12, 2013, 09:08:34 pm »
It worked! :)
[email protected]:~$ uname -a
Linux vishalcomp 3.2.34-030234-generic #201211161335 SMP Fri Nov 16 18:36:29 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Had to 'Enable Wireless' manually, though.
« Reply #151 on: October 12, 2013, 09:17:59 pm »
OK, to half the GRUB timer -
run:
sudo gedit /etc/default/grub
find the line that reads:-
GRUB_TIMEOUT=10
and change it to:-
GRUB_TIMEOUT=5
Back in the terminal run:
sudo update-grub
Reboot to test.
I'm hoping the having to manually enable wireless will sort itself .. as it did before .. so reboot a few times and let me know.
Offline vishal
« Reply #152 on: October 12, 2013, 09:34:42 pm »
It all works wonderfully! :) I too hope that issue of manually enabling wireless sorts out by itself.
Mark, you have been a great help and I just can't thank you enough! I learned a lot too through all of this!
Thank you once again! :)
« Reply #153 on: October 12, 2013, 09:43:15 pm »
you're welcome :)
Did the manually enabling wireless sort itself a while ago .. or have you ALWAYS had to enable it since we got it working ?
Offline vishal
« Reply #154 on: October 12, 2013, 09:55:03 pm »
It was auto connecting - till the system rebooted with 3.8 recovery mode. Since then, wireless needs to be enabled manually. I wonder what could have gone wrong with that seemingly innocuous reboot!
« Reply #155 on: October 12, 2013, 10:01:32 pm »
Dunno .. hopefully it will sort itself .. if it doesn't in a day or two, let me know and we'll look into a fix.
Theoretically we could write a script to enable wireless and set that to run at startup .. but I'd rather find out WHY it's not sticking across a breboot if it becomes necessary.
Offline vishal
« Reply #156 on: October 12, 2013, 10:06:58 pm »
Sure Mark! Will wait till Tuesday, and will let you know, whichever way it goes.
Once again, thank you so much for all your time - n - effort - n - patience. :)
« Reply #157 on: October 12, 2013, 10:26:32 pm »
Again .. you're more than welcome ;)
Offline Trof
« Reply #158 on: October 15, 2013, 08:39:42 am »
hello, Mark! can you help me with the same problem. i installed this drivers, and always get a kernel panic after try to connect. i can not understand what the problem, think another device may conflict with ralink adapter
« Reply #159 on: October 16, 2013, 02:39:57 am »
Hi Trof, and welcome to the forum :)
What's the output from:
uname -a
Offline vishal
« Reply #160 on: October 16, 2013, 08:00:32 am »
Hey Mark - even after multiple reboots, the system still needs manual intervention to enable wireless! Wonder, if we could do something to fix it.
« Reply #161 on: October 16, 2013, 11:58:08 am »
Is it just wifi you need to enable in networkmanager .. or networking ?
can you reboot (so wireless is OFF) then run this command to see if it enables it:
nmcli nm wifi on
if that doesn't work, try:
nmcli nm enabled true
If one of those works .. try adding the command as an autostart action.
Offline vishal
« Reply #162 on: October 17, 2013, 10:09:13 pm »
Hey Mark...sorry, couldn't reply earlier- was travelling. Added "nmcli nm wifi on" command to startup applications. Works wonderfully! Thank You! :)
« Reply #163 on: October 17, 2013, 10:13:40 pm »
You're welcome :)
Offline 031164
« Reply #164 on: October 19, 2013, 07:26:45 am »
HI, I follow the instruction on the first page but the file did not compile after the make file. Pls Help.
I am on Ubuntu 13.10.
