Author Topic: Adobe Flash player out of date on Chromium Solved  (Read 9875 times)
Offline Tramlink
  • Is the mist clearing
« on: September 29, 2012, 10:56:49 am »
As we know Adobe have stooped updating flash for Linux thus when I go to sites that want the latest flash version I get the drop down menu telling me flash is out of date.
Is there any way to stop the warning as it will never be possible to get an update?
Thanks.
« Last Edit: September 29, 2012, 11:08:29 pm by Tramlink »
Re: Adobe Flash player out of date on Chromium
« Reply #1 on: September 29, 2012, 11:51:37 am »
Couple of questions ..
Which Linux distribution/version/architecture .. eg. Ubuntu 12.04 64bit
Which version of Chromium are you using ?
Which version of Flash are you running ? .. you can find this out by opening Chromium, and entering this into the address bar:-
chrome://plugins/
and hitting enter .. then looking for "Shockwave Flash", which will be followed by a version number.
Offline Tramlink
« Reply #2 on: September 29, 2012, 04:44:44 pm »
Linux Mint
Release: 13 (maya)
Edition: MATE 64-bit
Chromium Version 20.0.1132.47 Built on Ubuntu 12.04, running on LinuxMint 13 (144678)
Flash 11.0r1
« Reply #3 on: September 29, 2012, 04:57:04 pm »
can you send the output from:
sudo find / -name libflashplayer.so
it will take that a short while to complete.
Offline Tramlink
« Reply #4 on: September 29, 2012, 07:32:13 pm »
userone@office2 ~ $ sudo find / -name libflashplayer.so
[sudo] password for userone:
/etc/alternatives/libflashplayer.so
/usr/lib/mozilla/plugins/libflashplayer.so
/var/lib/dpkg/alternatives/libflashplayer.so
/opt/mint-flashplugin-11/libflashplayer.so
userone@office2 ~ $
« Reply #5 on: September 29, 2012, 08:19:07 pm »
mkdir ~/.mozilla/plugins
cd ~/.mozilla/plugins
wget http://fpdownload.macromedia.com/get/flashplayer/pdc/11.2.202.238/install_flash_player_11_linux.x86_64.tar.gz
tar -xvf install_flash_player_11_linux.x86_64.tar.gz libflashplayer.so
Now close ALL web browser instances, and restart Chromium.  <-- this is IMPORTANT
in Chromium, go to this address:- chrome://plugins/
Scroll down the list of plugins and see if there's one listed called Shockwave Flash 11.2 r202
If there is .. disable ALL OTHER versions of Shockwave Flash (click the blue "disable" writing) versions, so that's the ONLY one enabled .. and restart Chromium.
If there isn't a version 11.2 r202 in the list .. let me know and we'lll try the 32bit flashplayer.
This is for my future reference if needed .. the address of the 32bit flashplayer:
http://fpdownload.macromedia.com/get/flashplayer/pdc/11.2.202.238/install_flash_player_11_linux.i386.tar.gz
Offline Tramlink
« Reply #6 on: September 29, 2012, 11:07:55 pm »
That's cracked it though I thought they had stopped updates for Linux systems.
Thanks.
Offline Tramlink
Re: Adobe Flash player out of date on Chromium Solved
« Reply #7 on: November 13, 2012, 11:44:19 am »
Now in need of the 32bit version.
« Reply #8 on: November 13, 2012, 12:29:11 pm »
Latest 32bit version -
wget http://fpdownload.macromedia.com/get/flashplayer/pdc/11.2.202.251/install_flash_player_11_linux_i386.tar.gz
tar -xvf install_flash_player_11_linux_i386.tar.gz libflashplayer.so
