Author Topic: [SOLVED] 'HOME directory is out of disk space', laptop refusing to boot  (Read 11400 times)
Offline inabitofapickle
  • Gender: Female
  • Hello hello
Re: 'HOME directory is out of disk space', laptop refusing to boot
« Reply #45 on: October 03, 2012, 03:22:11 am »
I'm typing this from my own (Pardus running) computer... It worked!
Thank you for you help, advice and patience.
My sticky notes, favourites and files all seem intact. I'll be shopping for that external hard drive in the morning (proper morning).
Thanks again
Debbie :)
« Reply #46 on: October 03, 2012, 03:23:48 am »
You're welcome :)
If you earlier deleted the ~/Music directory .. it may be a good idea to re-create it, as it's probably a system directory:
mkdir ~/Music
if it already exists, that command will fail .. but it won't hurt to run it.
  • Gender: Female
  • Hello hello
« Reply #47 on: October 03, 2012, 03:28:02 am »
I ran the command, it failed and when I checked, yes it did exist so the success is all down to your instruction :)
Thank you
« Reply #48 on: October 03, 2012, 03:29:29 am »
Have fun, and goodnight :)
  • Gender: Female
  • Hello hello
« Reply #49 on: October 03, 2012, 03:31:46 am »
Goodnight :)
Offline Deniz
Re: [SOLVED] 'HOME directory is out of disk space', laptop refusing to boot
« Reply #50 on: February 14, 2013, 03:56:47 pm »
THANK YOU Mark! You just saved my belowed Pardus system!
All the best!
« Reply #51 on: February 14, 2013, 04:28:18 pm »
Hi Deniz, and welcome to the forum :)
You're more than welcome .. glad it helped.
