Author Topic: install problem with Peppermint 3 on a Dell "Inspiron Mini" Netbook  (Read 8219 times)
Offline emily
Re: install problem with Peppermint 3 on a Dell "Inspiron Mini" Netbook
« Reply #15 on: October 16, 2012, 02:11:45 pm »
Hi, it didn't work. The screen that was blank (following the Dell screen) now shows the following information:
error: file not found.
grub rescue>
« Reply #16 on: October 16, 2012, 02:16:34 pm »
Can you open your file manager (menu>file Manager) and tell me if the left hand column still has a directory called "emily" and NOT one called "peppermint"
Offline emily
« Reply #17 on: October 16, 2012, 02:17:40 pm »
as it was before.
There is a drive called "emily" but not one called "peppermint"
« Reply #18 on: October 16, 2012, 02:22:50 pm »
OK, I think I know what's happened .. you ARE actually running Peppermint from the hard drive (NOT the LiveUSB) .. somehow you managed to install stage 1 of the GRUB bootloader to the LiveUSB stick, which then point to the hard drive installation .. so you ARE running from the hard drive, but it can't boot without the LiveUSB plugged in.
Open a terminal and run:
sudo grub-install /dev/sda
and reboot to the hard drive.
Offline emily
« Reply #19 on: October 16, 2012, 02:35:09 pm »
done - terminal replied  "Installation finished. No error reported"
did you need me to shut down ad restart again?
« Reply #20 on: October 16, 2012, 02:38:42 pm »
Yeh, reboot without the LiveUSB plugged in and tell me what happens
Offline emily
« Reply #21 on: October 16, 2012, 02:41:31 pm »
 :) worked!
Is that all sorted then?
« Reply #22 on: October 16, 2012, 02:43:25 pm »
Yup .. unless there's anything else not working .. but you can always come back with other questions :)
Is your wireless working ?
One other thing .. you might want to recreate that LiveUSB at some point .. if someone ever asks you to boot to your LiveUSB, it's broken (as GRUB stage 1 got written to it) .. its always handy to have a working LiveUSB in case you need it for fixing a broken system.
You'll know if it's working properly if when you boot to it there is NO drive called "emily" but there IS one called "peppermint" .. and there's an icon on the desktop called "Install Peppermint" ;)
« Last Edit: October 16, 2012, 02:52:21 pm by Mark Greaves (PCNetSpec) »
Offline emily
« Reply #23 on: October 16, 2012, 02:46:45 pm »
NO - (I had it plugged in on Ethernet for installation)
I have my access codes ready - can I have your help on that too?!
« Reply #24 on: October 16, 2012, 02:50:07 pm »
Sure .. first let's check the wireless card is being detected .. open a terminal and post the output from:
sudo lshw -C network
BTW, also read the edit I made to my last response .. no need to do that now, but at some point it would be a good idea.
Offline emily
« Reply #25 on: October 16, 2012, 03:01:30 pm »
here is the response. I have to go and pick up the kids now but will be back later - really appreciate your help.
emily@DellNetbook ~ $ sudo lshw -C network
[sudo] password for emily:
  *-network
       product: BCM4312 802.11b/g LP-PHY
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 01
       width: 64 bits
       configuration: driver=b43-pci-bridge latency=0
       resources: irq:17 memory:f0100000-f0103fff
  *-network
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: eth1
       version: 02
       serial: 00:24:e8:cf:43:dd
       capacity: 100Mbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=N/A ip=192.168.1.71 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:43 ioport:2000(size=256) memory:f0510000-f0510fff memory:f0500000-f050ffff memory:f0520000-f053ffff
  *-network DISABLED
       physical id: 2
       logical name: wlan1
       serial: 00:26:5e:63:97:11
       configuration: broadcast=yes driver=b43 driverversion=3.2.0-23-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bg
« Reply #26 on: October 16, 2012, 03:04:18 pm »
OK, catch ya later .. that'll give me time to do a bit of homework on the mini 10 wireless :)
« Reply #27 on: October 16, 2012, 03:50:27 pm »
OK, I seem to be getting conflicting reports as to the best driver/firmware for your wireless card .. so I think the best course of action would be to do a full system upgrade, then stick with the drivers its selected by default and see how it goes .. if the connection then seems "iffy" (eg. keeps dropping out) we'll try the lpphy (low power) firmware.
So first for the full system update .. open a terminal and run:
sudo apt-get upgrade
and if necessary hit "y" to accept the updates.
When that's done and leaves you back at an "$" prompt .. REBOOT.
Once rebooted, click the NetworkManager icon in the system tray (bottom left of screen, by the clock) .. can you see YOUR router in the list ?
If so, click it .. you should then be prompted for your wireless key .. enter it and click "Connect" (remember your wireless key IS case sensitive) .. did it connect ?
Are you now able to access the internet without the ethernet cable ?
If so, reboot to test it connects automatically .. does it ?
If so, test it for a while and make sure it doesn't keep dropping the connection.
« Last Edit: October 16, 2012, 05:04:49 pm by Mark Greaves (PCNetSpec) »
Offline emily
« Reply #28 on: October 16, 2012, 05:31:19 pm »
Hi again,
I got as far as entering the second the command and left it to finish. I am now presented with a Package configuration screen asking me where to put the "Grub Install Devices". I will forward a screen shot in a moment.
Offline emily
« Reply #29 on: October 16, 2012, 05:32:28 pm »
attached
