Author Topic: install problem with Peppermint 3 on a Dell "Inspiron Mini" Netbook  (Read 8253 times)
Re: install problem with Peppermint 3 on a Dell "Inspiron Mini" Netbook
« Reply #30 on: October 16, 2012, 05:46:59 pm »
you want the /dev/sda one .. so hit the space bar so theres an asterisk in the
(*) /dev/sda
option .. then hit the tab key till OK is highlighted red at the bottom .. then hit enter to continue.
« Last Edit: October 16, 2012, 05:49:34 pm by Mark Greaves (PCNetSpec) »
Offline emily
« Reply #31 on: October 16, 2012, 06:23:20 pm »
Hi again, okay all that done and ethernet cable unplugged.
My router is not showing up in the list in "Network Connections" though so can't get any further at the moment.
good news is it is booting up well and is nice and quick too  :)
« Reply #32 on: October 16, 2012, 06:38:27 pm »
Can you post the output from:
ifconfig
iwconfig
iwlist scanning
rfkill list
Offline emily
« Reply #33 on: October 16, 2012, 09:24:01 pm »
hi again, here it is
emily@DellNetbook ~ $ ifconfig
eth1      Link encap:Ethernet  HWaddr 00:24:e8:cf:43:dd
          inet addr:192.168.1.71  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::224:e8ff:fecf:43dd/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1063 errors:0 dropped:0 overruns:0 frame:0
          TX packets:484 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:275533 (275.5 KB)  TX bytes:49811 (49.8 KB)
          Interrupt:43
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:1418 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1418 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:113584 (113.5 KB)  TX bytes:113584 (113.5 KB)
emily@DellNetbook ~ $ iwconfig
wlan1     IEEE 802.11bg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
eth1      no wireless extensions.
emily@DellNetbook ~ $ iwlist scanning
wlan1     Failed to read scan data : Network is down
eth1      Interface doesn't support scanning.
emily@DellNetbook ~ $ rfkill list
0: compal-wifi: Wireless LAN
   Soft blocked: no
   Hard blocked: no
1: compal-bluetooth: Bluetooth
   Soft blocked: no
   Hard blocked: no
2: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
« Reply #34 on: October 16, 2012, 09:30:25 pm »
OK, lets try this first ..
sudo apt-get install b43-fwcutter firmware-b43-lpphy-installer
Once that's done .. reboot .. then see if your router is visible.
Offline emily
« Reply #35 on: October 16, 2012, 09:43:45 pm »
Hello again. I am now contacting you using the wireless network on the Dell Netbook. Brilliant!
Many thanks. I am very impressed with the quality of support on offer here.
Am afraid that you have not heard the last of me just yet as have also put Peppermint 3 on an old desktop that was not working. It all seems fine except the screen graphics which are distorted. Do I need to start a new topic to get some help with that?
« Reply #36 on: October 16, 2012, 09:46:17 pm »
Yeh, would probably be a good idea .. this has "Dell Inspiron Mini" in the title ;)
Offline emily
« Reply #37 on: October 16, 2012, 09:48:04 pm »
will do that tomorrow! thanks again and have a good evening.
« Reply #38 on: October 16, 2012, 09:51:36 pm »
You're more than welcome :)
