Author Topic: [SOLVED] downloading java  (Read 2229 times)
Offline banko
  • Full Member
« on: October 15, 2012, 03:16:45 pm »
Hi Mark
I need to download java to my netbook on peppermint 3, so i can swap files both ways from my smartphone using kies air.
needless to say i need a little help, as theres more than one java package,
thanks in anticipation.
« Last Edit: October 15, 2012, 05:46:18 pm by banko »
Re: downloading java
« Reply #1 on: October 15, 2012, 04:41:16 pm »
OK, this worked for me in Peppermint 3 32bit .. it will remove the openJDK/IcedTea JRE and plugin, and install the Oracle Java 7 JRE and plugin.
First lets get rid of the openjdk/icedtea java stuff:
sudo apt-get purge openjdk*
Now add a PPA and install Oracle java 7:
sudo add-apt-repository ppa:webupd8team/java
then:
then:
sudo apt-get install oracle-java7-installer
At some point it will ask you to accept a license .. use the tab key to make sure "OK" is highlighted in RED, then hit enter .. on the next screen, use the tab key to select "Yes" and hit enter.
Let it run till it returns you to an $ prompt .. may take a short while (specially on an AA1) .. it appears to stop at "Downloading Done." but just wait it isn't done till it returns you to an $ prompt.
OK for some reason the update-alternatives links now seem broken, so back in the terminal run:
sudo update-alternatives --install /usr/bin/javac javac /usr/lib/jvm/java-7-oracle/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/java-7-oracle/bin/java 1
OK, now 2 tests to see if Java  is working correctly -
Open a terminal and run:
java -version
This should be returned:-
java version "1.7.0_07"
Java(TM) SE Runtime Environment (build 1.7.0_07-b10)
Java HotSpot(TM) Client VM (build 23.3-b01, mixed mode)
Then in your web browser ..
Go to this page:
http://www.java.com/en/download/testjava.jsp
It *should* say -
Your Java is working
Vendor: Oracle Corporation
Version: Java SE 7 Update 07
Links for reference:
http://www.ubuntugeek.com/how-to-install-oracle-java-7-in-ubuntu-12-04.html#more-13048
http://maketecheasier.com/install-java-runtime-in-ubuntu/2012/05/14
« Last Edit: October 15, 2012, 04:48:06 pm by Mark Greaves (PCNetSpec) »
Offline banko
  • Full Member
Re: downloading java [SOLVED]
« Reply #2 on: October 15, 2012, 05:44:33 pm »
Thanks Mark.
works perfect,
checked phone and kies air works both ways, which it does.
again thanks
Keith   :D
Re: [SOLVED] downloading java
« Reply #3 on: October 15, 2012, 06:09:52 pm »
You're welcome :)
Thanks for marking the topic (SOLVED).
« Last Edit: October 15, 2012, 06:19:20 pm by Mark Greaves (PCNetSpec) »
