Author Topic: video software  (Read 1032 times)
Offline Aitch
video software
« on: October 15, 2012, 11:28:37 pm »
I have a Panasonic Lumix. Does anyone know if there is software which will recognise the video with Ubuntu?
Re: video software
« Reply #1 on: October 15, 2012, 11:35:21 pm »
Hi Aitch, and welcome to the forum :)
If they are AVCHD files (.mts) .. this topic may be of interest:
http://linuxforums.org.uk/index.php?topic=9627.0
Lightworks (beta) is also due out for Linux on or around the 30th of this month .. and I'm sure I read somewhere that will be able to edit AVCHD too :)
Does VLC 2.0.3 not support AVCHD (.mts) ?
Someone in another forum suggests VLC 2.x.x will play .mts (AVCHD) fies, but they're jerky .. the suggested fix is -
In VLC 2.x.x ..
Go to Tools > Preferences
In the lower left of the box click the checkbox Show settings All
Then go to Input/Codecs > Video Codecs > FFmpeg and look for the option called Skip the loop filter for H.264 decoding
Change it from None to All
Then restart VLC
I can't test this, as I don't have any .mts files .. but worth a shot ;)
« Last Edit: October 16, 2012, 12:01:14 am by Mark Greaves (PCNetSpec) »
