Author Topic: Who remembers Betamax ?  (Read 53334 times)
Offline SeZo
Re: Who remembers Betamax ?
« Reply #255 on: January 08, 2013, 11:24:36 pm »
I was too, but hey it is just another way that it does not work. :'(
Also it is possible that it was/is a non starter as there is no internal output from your card,hence no /dev/dsp.
There is another option, to kill PulseAudio and then try it again (it might be a long shot)
sudo killall pulseaudio
After that I think I will be ready to throw in the towel.
« Reply #256 on: January 08, 2013, 11:29:23 pm »
Not stepping on SeZo's toes .. but ..
If I were you I'd remove oss-compat .. every time I've installed it, it plays havoc with the PulseAudio controls
Not to mention oss-compat CANNOT work without loading snd-pcm-oss (the driver they've removed from the kernel) to provide /dev/dsp  ::)  <--- this is the EXACT reason I don't think you'll get xawtv to work, as CAPTURING from OSS's /dev/dsp seems hardcoded into xawtv.
Actually .. thinking about it, it may not have been oss-compat, it may have been oss4-base (tried that too) .. but as I said oss-compat is broken in recent versions of Ubuntu/Mint/Peppermint anyway, so no point in having it installed.
All I'm saying is if you notice any audio problems, try removing oss-compat which is broken anyway.
According to <a href="http://http://pkgs.org/ubuntu-12.04/ubuntu-universe-i386/oss-compat_1_all.deb.html">this site[/url] oss-compat is available for Ubuntu 12.04.1 LTS
This package ensures that Open Sound System support is provided in some way. On Linux, it enables the ALSA compatibility modules. On other kernels where OSS is the default interface, no action is taken.
The purpose of this package is for applications that only support OSS
to depend on it, hence preventing common "/dev/dsp not found" errors that would confuse unexperienced users.
Yeh that's what it's SUPPOSED to do  ::) .. but it can't provide /dev/dsp without first modprobe-ing the snd-pcm-oss (and if wanted snd-mixer-oss and snd-seq-oss) kernel module .. which doesn't exist  ::)
Try doing:
modinfo snd-pcm-oss
you'll see what I mean .. the other 2 still exist, but thanks (sarcasm) to the people at Ubuntu, the important one (the one that makes oss-compat work) doesn't.
« Last Edit: January 08, 2013, 11:51:21 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #257 on: January 09, 2013, 06:44:59 am »
I tried that didn't work
I don't blame you but no one can fault you for effort :)
From what Mark is saying it looks like xawtv is not gonna work no matter what we do  which is frustrating because we're so close, I don't know if you and Mark think it's worthwhile exploring other options with this card, if not I'll understand and thank you both for your efforts
Many thanks
« Reply #258 on: January 09, 2013, 04:33:03 pm »
Give me a day or two to test other distros, and/or look for a kernel with snd-pcm-oss compiled in.
That's the ONLY way (AFAIK) to get) oss-compat to work .. and therefore xawtv.
(on either card)
Emegra
  • Guest
« Reply #259 on: January 09, 2013, 04:38:56 pm »
ok no problem but just out of curiosity what about Cheese or guview would getting either of them to work be an easier solution. I'm not double guessing you Mark, I'm just curious :)
« Reply #260 on: January 09, 2013, 05:17:34 pm »
So what happens with guvcview ?
and does running it from the terminal give any cues ?
Emegra
  • Guest
« Reply #261 on: January 09, 2013, 05:21:19 pm »
It just doesn't open I've tried un-installing and re-installing
I don't know, I'm at work at the moment but I'll try that and report back
Many thanks
Emegra
  • Guest
« Reply #262 on: January 09, 2013, 06:15:46 pm »
Hi again
Here's the output for opewning guvcview
[email protected] ~ $ guvcview
guvcview 1.5.3
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib audio/pcm_bluetooth.c:1614:(audioservice_expect) BT_GET_CAPABILITIES failed : Input/output error(5)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
video device: /dev/video0
Unable to find parent usb device.Unable to find parent usb device.Init. BT848A video (Hauppauge (bt848) (location: PCI:0000:02:02.0)
{ pixelformat = 'GREY', description = '8 bpp, gray' }
VIDIOC_ENUM_FRAMESIZES - Error enumerating frame sizes: Inappropriate ioctl for device
  Unable to enumerate frame sizes.
{ pixelformat = 'HI24', description = '8 bpp, dithered color' }
   { not supported - request format(875710792) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBO', description = '15 bpp RGB, le' }
   { not supported - request format(1329743698) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBQ', description = '15 bpp RGB, be' }
   { not supported - request format(1363298130) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBP', description = '16 bpp RGB, le' }
   { not supported - request format(1346520914) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBR', description = '16 bpp RGB, be' }
   { not supported - request format(1380075346) support at http://guvcview.sourceforge.net }
{ pixelformat = 'BGR3', description = '24 bpp RGB, le' }
{ ?GSPCA? : width = 640, height = 480 }
fmtind:2 fsizeind: 1
{ pixelformat = 'BGR4', description = '32 bpp RGB, le' }
   { not supported - request format(877807426) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGB4', description = '32 bpp RGB, be' }
   { not supported - request format(876758866) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YUYV', description = '4:2:2, packed, YUYV' }
{ pixelformat = 'UYVY', description = '4:2:2, packed, UYVY' }
{ pixelformat = '422P', description = '4:2:2, planar, Y-Cb-Cr' }
   { not supported - request format(1345466932) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YU12', description = '4:2:0, planar, Y-Cb-Cr' }
fmtind:6 fsizeind: 1
{ pixelformat = 'YV12', description = '4:2:0, planar, Y-Cr-Cb' }
fmtind:7 fsizeind: 1
{ pixelformat = '411P', description = '4:1:1, planar, Y-Cb-Cr' }
   { not supported - request format(1345401140) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YUV9', description = '4:1:0, planar, Y-Cb-Cr' }
   { not supported - request format(961959257) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YVU9', description = '4:1:0, planar, Y-Cr-Cb' }
   { not supported - request format(961893977) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGB3', description = 'RGB3' }
fmtind:8 fsizeind: 1
vid:0000
pid:0000
driver:bttv
checking format: 1196444237
Format unavailable: 1196444237.
Init v4L2 failed !!
Init video returned -2
trying minimum setup ...
Segmentation fault (core dumped)
« Reply #263 on: January 09, 2013, 08:45:28 pm »
I haven't really had a close look .. but it looks like bluetooth might be causing an issue, can you remove the bluetooth device, reboot, and try again.
Also, make sre you've tuned in the video with xawtv first.
If that helps .. you might also want to try cheese without the bluetooth device connected.
« Last Edit: January 09, 2013, 08:49:12 pm by Mark Greaves (PCNetSpec) »
