Author Topic: Peppermint OS3 Skype install - limited usage  (Read 9078 times)
Offline nerobert
« on: January 15, 2013, 01:31:28 pm »
Hi there,
I've installed Peppermint OS3 and have Skype 4.1.0.20 but it appears very limited and there is no video.
I am guessing I have to install drivers for the internal camera on my Acer Aspire One Netbook and that I also need a higher version of Skype. (I have tried to install versions from Skype.com, but it says the installed copy is a higher version!)
My question is - What do I need to do to get a normal looking version of Skype and working video?
Has anyone else needed to do this before?
Thanks,
Neil
Re: Peppermint OS3 Skype install - limited usage
« Reply #1 on: January 15, 2013, 03:39:36 pm »
Hi nerobert, and welcome to the forum.
I'm not understanding your problem with Skype ???
(I'm trying to get a handle on whether this is a user, hardware, or software problem .. as it works perfectly on both my AA1's)
Fire up Skype .. login to Skype .. then a little Skype icon should appear down by your system clock, if you right-click that and select Options .. then in the left hand column of the widow that appears select Video Devices
Is Enable Skype Video ticked ? .. and can you see your webcam image ?
Can you mention what model of Acer Aspire One you have .. Example = AOA110L
« Last Edit: January 15, 2013, 05:22:04 pm by Mark Greaves (PCNetSpec) »
Offline Tramlink
  • Is the mist clearing
« Reply #2 on: January 16, 2013, 02:39:30 pm »
HI you have the newest version of Skype for Linux.
Have you tested your video is working using the software that is installed in Peppermint.
I have no problems and I am using a 12 year old laptop.
Offline nerobert
« Reply #3 on: January 16, 2013, 05:28:41 pm »
Thanks for the posts, very useful.
It looks fixed. I did a bit more research and the problem is Skype knowing about the camera.
After a few false starts I did this:
  $ sudo gedit /usr/local/bin/skype
Then put this into the new file:
  #!/bin/bash
  LD_PRELOAD=/usr/lib/libv41/v4llcompat.so /usr/bin/skype
Then saved the file and made it an executable with
  $ sudo chmod a+x /usr/local/bin/skype
After running it, skype now has access to the video camera and works to send and receive video calls.
Thanks for the ideas, this a brilliant forum and has given my machine a new lease of life.
Now ... a more difficult problem ... getting my daughter off the machine. She loves it!
Thanks everyone.
Neil
« Reply #4 on: January 16, 2013, 05:30:44 pm »
Glad to hear you solved it .. and thanks for taking the time to post the solution :)
Offline spence
« Reply #5 on: February 22, 2013, 03:56:39 pm »
hey guys, mind my asking how you all went about installing skype into your peppermintOS in the first place? i've never used skype previously....
« Reply #6 on: February 22, 2013, 04:05:02 pm »
Go to menu>Preferences>Software Sources
Click the "Other Software" tab
Make sure "Canonical Partners" is ticked.
click "Close".
Open a terminal and run:
sudo apt-get install skype
You'll then find it at:-
menu>Internet>Skype
Offline Traveler
  • Keeping it real.
« Reply #7 on: June 12, 2013, 04:53:20 am »
iI did all that and get "E: Unable to locate package skype"
Any suggestions?
Mike
Semper Fi!
Mike aka W3TWG
Tamer of Dragons!
« Reply #8 on: June 12, 2013, 10:47:16 am »
First see here:-
http://linuxforums.org.uk/index.php?topic=10313.msg84154#msg84154
If that still doesn't work .. post the contents of:
gedit /etc/apt/sources.list
Offline A Future Pilot
  • Descent Player
« Reply #9 on: June 15, 2013, 09:37:01 pm »
This is actually on P4, but I'm trying to use Skype, and my girlfriend complains of too much background noise. If I turn down capture in alsamixer, she says she can't hear me, but if I turn it up, there's too much noise.
I don't THINK this is a problem with Skype on Linux, cause I had it working in P3 (but I remember I had to do a lot of tweaks to get it working right.)
Any suggestions?
Thanks!
« Reply #10 on: June 15, 2013, 09:49:41 pm »
Have you tried the same instructions as for Peppermint 3 ? .. see here:
http://linuxforums.org.uk/index.php?topic=10313.msg76522#msg76522
  • Descent Player
« Reply #11 on: June 17, 2013, 01:47:05 pm »
Oh! Lol! HERE'S where that link is I was talking about :)
« Reply #12 on: June 17, 2013, 01:49:01 pm »
Heh .. just posted to the other topic :)
