Author Topic: Openmediavault (Solved)  (Read 48311 times)
Emegra
  • Guest
Re: Openmediavault
« Reply #135 on: March 06, 2013, 11:30:55 pm »
can you now connect to the web UI on 192.168.2.151
Yes that's it
thank you so much for your perseverance you've went above and beyond the call of duty once again
@SeZO thank you also for your help it's much appreciated
I'll mark this solved
Many thanks
Re: Openmediavault (Solved)
« Reply #136 on: March 06, 2013, 11:43:31 pm »
We may need to comment out (or change the addresses of) the
allow-hotplug eth0
line (section) in /etc/network/interfaces
to stop it automagically coming up every boot, and messing up wireless again.
So it aint quite solved yet ;)
« Last Edit: March 06, 2013, 11:51:05 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #137 on: March 07, 2013, 11:56:20 am »
Hi Mark
I did as you suggested and commented out "Allow-hotplug eth0 in the /etc/network/interfaces file and it's working fine,
There are still some problems downloading certain services from within the web gui and mounting or creating one particular volume (that happens to have a Windows & Linux partition on it) I may have to wipe these partitions first but I'm not sure how to do that in the NAS terminal, alternatively I suppose I can run any live Linux disc on the NAS and use gparted, but so far I haven't had a lot of time to spend with it so I'll mess around with it tonight and let you know if I have any problems, I also installed puTTY on my pc so I can now log into the NAS via ssh which should make things easier (one keyboard)
Many thanks
« Reply #138 on: March 07, 2013, 12:00:50 pm »
We should be able to mount the partitions through fstab .. or you can do as you suggest .. you know where to come if you require assistance ;)
Have you tested you can get the WebUI wirelessly after a reboot ?
« Last Edit: March 07, 2013, 12:03:19 pm by Mark Greaves (PCNetSpec) »
Emegra
  • Guest
« Reply #139 on: March 07, 2013, 08:51:56 pm »
Hi Mark
Yes I've tested that and it works perfectly,
So now I can work inside the web GUI  although I'm having many issues (mounting/sharing etc), but I can't keep coming on here pestering people to help me with things that I probably shouldn't be getting involved with in the first place, so I'll try to figure out what I can myself and perhaps start a new thread with any problems I can't figure out.
Many thanks to for all the help I've had so far
« Last Edit: March 07, 2013, 08:53:33 pm by Emegra »
« Reply #140 on: March 07, 2013, 08:57:11 pm »
Okey Dokey, your call .. but bear in mind, nobody here minds giving assistance otherwise they wouldn't be here ;)
