Author Topic: Peppermint Software  (Read 4105 times)
Offline mako6
  • Full Member
Peppermint Software
« on: March 06, 2013, 01:04:58 pm »
What are the right files to download for UBUNTU ONE? I never know if the software center is doing the right thing (one comment said also needed front-end), Synaptic lists 20-25 related programs.  Can one just trust "apt-get install" ubuntu one? Installed the Ubuntu1 installer, but not sure if it will do the cleanest install for Ubuntu.
I also need a decent simple web editor. Wanted SeaMonkey, since I have it on laptop, but it doesn't seem available now, and my searches aren't turning up alternatives.
Re: Peppermint Software
« Reply #1 on: March 06, 2013, 03:14:18 pm »
Offline mako6
  • Full Member
« Reply #2 on: March 06, 2013, 10:51:51 pm »
Should I remove the Installer?
Is Seamonkey available anywhere?
« Reply #3 on: March 06, 2013, 10:54:35 pm »
What installer ?
I'll come back to your seamonkey question later
OK to install seaamonkey ..
run:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com C1289A29
then:
When a file opens with a ton of stuff in it .. add 2 NEW lines at the bottom that read:-
# Ubuntuzilla (Seamonkey) PPA
deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt all main
SAVE the file, and close gedit.
Back in the terminal run:
sudo apt-get install seamonkey-mozilla-build
You'll then find Seamonkey 2.16 in the menus at
menu>Internet>Mozilla Build of Seamonkey
« Last Edit: March 06, 2013, 11:36:59 pm by Mark Greaves (PCNetSpec) »
Offline mako6
  • Full Member
« Reply #4 on: March 07, 2013, 01:06:40 am »
Jeez, how do you find this stuff? Why do you need a keys instruction with secret codes? Not that I doubt you, just seems exorbitent.
As I said, of all the 15-20 listed Ubuntu One apps in Synaptic, I installed one- the U1 installer, which opens under preferences and offers to install U1. Thanks.
« Reply #5 on: March 07, 2013, 01:23:27 am »
Yeh, I'd uninstall it then :)
