Author Topic: Acer one ZGS with peppermint 2 (?) cant reinstall libre office  (Read 25534 times)
Offline 16fairfield
Hi   wanted to read ppt on my netbook  so tried with software manager to install the appropriate package but it did not install so tried to install libreoffice 4. The remove old version worked but the new install although it ran did not install. I am now without any libreoffice products. :'(
All help gratefully received.
Nigel
Re: Acer one ZGS with peppermint 2 (?) cant reinstall libre office
« Reply #1 on: March 23, 2013, 10:58:52 am »
How did you try to install LO4 ? .. from the PPA ? .. that won't work, as Peppermint 2 is now end of life.
You have 3 options -
1) Remove the PPA and reinstall LO3.
2) Download the LO4 .deb files and install them:
http://www.libreoffice.org/download
3) Install Peppermint 3 which still has 4 years support to go.
First I'd try option 2 .. if you want instructions, just ask :)
« Last Edit: March 23, 2013, 11:10:48 am by Mark Greaves (PCNetSpec) »
Offline 16fairfield
« Reply #2 on: March 23, 2013, 01:26:16 pm »
Hi
can you provide an  idiot guide to the install as tried to follow the libreoffice instructions and it didnt seem to work    from memory it seemed to ask for aptitude which i dont appear to have
thanks
Offline SeZo
« Reply #3 on: March 23, 2013, 03:18:22 pm »
What application were you trying to install?
My understanding is that LO 3.x can open ppt files in impress ???
If you just want to re-install Libreoffice then try:
sudo apt-get install libreoffice-calc libreoffice-writer libreoffice-draw libreoffice-impress
See if that will install all the bits needed
« Reply #4 on: March 23, 2013, 04:13:24 pm »
[FIXED Instructions]
To install LO4 .. open a terminal (Ctrl+Alt+T) and run these commands in sequence:
sudo apt-get remove --purge libreoffice*
mkdir -p ~/Desktop/delete-me/main ~/Desktop/delete-me/langpack ~/Desktop/delete-me/helppack
cd ~/Desktop/delete-me/main
wget http://download.documentfoundation.org/libreoffice/stable/4.0.1/deb/x86/LibreOffice_4.0.1_Linux_x86_deb.tar.gz
tar -xvf LibreOffice_4.0.1_Linux_x86_deb.tar.gz
cd ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb/DEBS
sudo dpkg -i *.deb
cd ~/Desktop/delete-me/langpack
wget http://download.documentfoundation.org/libreoffice/stable/4.0.1/deb/x86/LibreOffice_4.0.1_Linux_x86_deb_langpack_en-GB.tar.gz
tar -xvf LibreOffice_4.0.1_Linux_x86_deb_langpack_en-GB.tar.gz
cd ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB/DEBS
sudo dpkg -i *.deb
cd ~/Desktop/delete-me/helppack
wget http://download.documentfoundation.org/libreoffice/stable/4.0.1/deb/x86/LibreOffice_4.0.1_Linux_x86_deb_helppack_en-GB.tar.gz
tar -xvf LibreOffice_4.0.1_Linux_x86_deb_helppack_en-GB.tar.gz
cd ~/Desktop/delete-me/helppack/LibreOffice_4.0.1.2_Linux_x86_deb_helppack_en-GB/DEBS
sudo dpkg -i *.deb
« Last Edit: March 23, 2013, 10:34:38 pm by Mark Greaves (PCNetSpec) »
Offline 16fairfield
« Reply #5 on: March 23, 2013, 08:55:26 pm »
Mark
all the steps work with the exception of the  *.deb ones  see example below
nigel@nigel-AOA150 ~/Desktop/delete-me/helppack $ sudo dpkg -i *.deb
dpkg: error processing *.deb (--install):
 cannot access archive: No such file or directory
 *.deb
nothing seems to be in menu for libre office
Offline 16fairfield
« Reply #6 on: March 23, 2013, 08:58:08 pm »
Sezo
tried your suggestion before Mark's but nothing was installed
« Reply #7 on: March 23, 2013, 09:07:58 pm »
OK, my miistake .. I'll fix the above instructions, but you just need to run:
sudo dpkg -i *.deb
sudo dpkg -i *.deb
sudo dpkg -i *.deb
Fixed in original posting too :)
« Last Edit: March 23, 2013, 09:12:33 pm by Mark Greaves (PCNetSpec) »
Offline 16fairfield
« Reply #8 on: March 23, 2013, 10:07:25 pm »
hi   this is what happened - nothing appears in menu
nigel@nigel-AOA150 ~ $ cd ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb
nigel@nigel-AOA150 ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb $ sudo dpkg -i *.deb
[sudo] password for nigel:
 *.deb
nigel@nigel-AOA150 ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb $ cd ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB
nigel@nigel-AOA150 ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB $ sudo dpkg -i *.deb
 *.deb
nigel@nigel-AOA150 ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB $ cd ~/Desktop/delete-me/helppack/LibreOffice_4.0.1.2_Linux_x86_deb_helppack_en-GB
nigel@nigel-AOA150 ~/Desktop/delete-me/helppack/LibreOffice_4.0.1.2_Linux_x86_deb_helppack_en-GB $ sudo dpkg -i *.deb
 *.deb
« Reply #9 on: March 23, 2013, 10:32:43 pm »
Third times a charm ..
OK, my mistake AGAIN  :-[ .. I'll fix the above instructions, but you just need to run:
sudo dpkg -i *.deb
sudo dpkg -i *.deb
sudo dpkg -i *.deb
Fixed AGAIN in original posting too :)
Offline 16fairfield
« Reply #10 on: March 24, 2013, 08:53:33 am »
Hi
all ran with no issues    still have a delete -me folder on desktop   and no libre office applications appear installed
all help appreciated
Nigel
« Reply #11 on: March 24, 2013, 11:03:27 am »
What happens if you run:
libreoffice
libreoffice --writer
libreoffice --calc
libreoffice --draw
libreoffice --impress
libreoffice --base
libreoffice --math
in  a terminal ?
If those all work, we can easily create or edit the .desktop files so they appear in the menus :)
« Last Edit: March 24, 2013, 11:18:35 am by Mark Greaves (PCNetSpec) »
Offline 16fairfield
« Reply #12 on: March 24, 2013, 11:56:06 am »
hi
see below    unsure if should have gone yes
nigel@nigel-AOA150 ~ $ libreoffice
The program 'libreoffice' is currently not installed.  You can install it by typing:
sudo apt-get install libreoffice-common
nigel@nigel-AOA150 ~ $ sudo apt-get install libreoffice-common
Reading package lists... Done
Building dependency tree
  sane-utils libcolamd2.7.1 lp-solve libfile-copy-recursive-perl
  libaccess-bridge-java-jni libaccess-bridge-java update-inetd
Use 'apt-get autoremove' to remove them.
  libreoffice-core libreoffice-style-human
Suggested packages:
  libreoffice-style-hicontrast libreoffice-style-tango
  libreoffice-style-crystal libreoffice-style-oxygen kde-icons-crystal
  crystalcursors
The following NEW packages will be installed:
  libreoffice-common libreoffice-core libreoffice-style-human
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 47.4 MB of archives.
After this operation, 167 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Err http://mirror01.th.ifl.net/ubuntu/ natty-security/main libreoffice-core i386 1:3.3.4-0ubuntu1.4
  Unable to connect to mirror01.th.ifl.net:http:
Err http://mirror01.th.ifl.net/ubuntu/ natty-security/main libreoffice-style-human all 1:3.3.4-0ubuntu1.4
Err http://mirror01.th.ifl.net/ubuntu/ natty-security/main libreoffice-common all 1:3.3.4-0ubuntu1.4
Failed to fetch http://mirror01.th.ifl.net/ubuntu/pool/main/libr/libreoffice/libreoffice-core_3.3.4-0ubuntu1.4_i386.deb  Unable to connect to mirror01.th.ifl.net:http:
Failed to fetch http://mirror01.th.ifl.net/ubuntu/pool/main/libr/libreoffice/libreoffice-style-human_3.3.4-0ubuntu1.4_all.deb  Unable to connect to mirror01.th.ifl.net:http:
Failed to fetch http://mirror01.th.ifl.net/ubuntu/pool/main/libr/libreoffice/libreoffice-common_3.3.4-0ubuntu1.4_all.deb  Unable to connect to mirror01.th.ifl.net:http:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
also tried
nigel@nigel-AOA150 ~ $ run libreoffice --writer
No command 'run' found, did you mean:
 Command 'crun' from package 'ceph' (universe)
 Command 'zrun' from package 'moreutils' (universe)
 Command 'runq' from package 'exim4-daemon-heavy' (main)
 Command 'runq' from package 'sendmail-bin' (universe)
 Command 'runq' from package 'exim4-daemon-light' (main)
 Command 'grun' from package 'grun' (universe)
 Command 'qrun' from package 'torque-client' (universe)
 Command 'qrun' from package 'torque-client-x11' (universe)
 Command 'lrun' from package 'lustre-utils' (universe)
 Command 'rn' from package 'trn' (multiverse)
 Command 'rn' from package 'trn4' (multiverse)
 Command 'rup' from package 'rstat-client' (universe)
 Command 'srun' from package 'slurm-llnl' (universe)
run: command not found
« Reply #13 on: March 24, 2013, 03:27:51 pm »
What is the output from:
ls -a ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb/DEBS
ls -a ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB/DEBS
ls -a ~/Desktop/delete-me/helppack/LibreOffice_4.0.1.2_Linux_x86_deb_helppack_en-GB/DEBS
cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; done
Offline 16fairfield
« Reply #14 on: March 24, 2013, 04:47:55 pm »
Here
nigel@nigel-AOA150 ~ $ ls -a ~/Desktop/delete-me/main/LibreOffice_4.0.1.2_Linux_x86_deb/DEBS
desktop-integration
libobasis4.0-base_4.0.1.2-2_i386.deb
libobasis4.0-calc_4.0.1.2-2_i386.deb
libobasis4.0-core01_4.0.1.2-2_i386.deb
libobasis4.0-core02_4.0.1.2-2_i386.deb
libobasis4.0-core03_4.0.1.2-2_i386.deb
libobasis4.0-core04_4.0.1.2-2_i386.deb
libobasis4.0-core05_4.0.1.2-2_i386.deb
libobasis4.0-core06_4.0.1.2-2_i386.deb
libobasis4.0-core07_4.0.1.2-2_i386.deb
libobasis4.0-draw_4.0.1.2-2_i386.deb
libobasis4.0-en-us_4.0.1.2-2_i386.deb
libobasis4.0-en-us-base_4.0.1.2-2_i386.deb
libobasis4.0-en-us-calc_4.0.1.2-2_i386.deb
libobasis4.0-en-us-math_4.0.1.2-2_i386.deb
libobasis4.0-en-us-res_4.0.1.2-2_i386.deb
libobasis4.0-en-us-writer_4.0.1.2-2_i386.deb
libobasis4.0-extension-beanshell-script-provider_4.0.1.2-2_i386.deb
libobasis4.0-extension-javascript-script-provider_4.0.1.2-2_i386.deb
libobasis4.0-extension-mediawiki-publisher_4.0.1.2-2_i386.deb
libobasis4.0-extension-nlpsolver_4.0.1.2-2_i386.deb
libobasis4.0-extension-presentation-minimizer_4.0.1.2-2_i386.deb
libobasis4.0-extension-python-script-provider_4.0.1.2-2_i386.deb
libobasis4.0-extension-report-builder_4.0.1.2-2_i386.deb
libobasis4.0-gnome-integration_4.0.1.2-2_i386.deb
libobasis4.0-graphicfilter_4.0.1.2-2_i386.deb
libobasis4.0-images_4.0.1.2-2_i386.deb
libobasis4.0-impress_4.0.1.2-2_i386.deb
libobasis4.0-javafilter_4.0.1.2-2_i386.deb
libobasis4.0-kde-integration_4.0.1.2-2_i386.deb
libobasis4.0-librelogo_4.0.1.2-2_i386.deb
libobasis4.0-math_4.0.1.2-2_i386.deb
libobasis4.0-ogltrans_4.0.1.2-2_i386.deb
libobasis4.0-onlineupdate_4.0.1.2-2_i386.deb
libobasis4.0-ooofonts_4.0.1.2-2_i386.deb
libobasis4.0-ooolinguistic_4.0.1.2-2_i386.deb
libobasis4.0-postgresql-sdbc_4.0.1.2-2_i386.deb
libobasis4.0-pyuno_4.0.1.2-2_i386.deb
libobasis4.0-writer_4.0.1.2-2_i386.deb
libobasis4.0-xsltfilter_4.0.1.2-2_i386.deb
libreoffice4.0_4.0.1.2-2_i386.deb
libreoffice4.0-base_4.0.1.2-2_i386.deb
libreoffice4.0-calc_4.0.1.2-2_i386.deb
libreoffice4.0-dict-en_4.0.1.2-2_i386.deb
libreoffice4.0-dict-es_4.0.1.2-2_i386.deb
libreoffice4.0-dict-fr_4.0.1.2-2_i386.deb
libreoffice4.0-draw_4.0.1.2-2_i386.deb
libreoffice4.0-en-us_4.0.1.2-2_i386.deb
libreoffice4.0-impress_4.0.1.2-2_i386.deb
libreoffice4.0-math_4.0.1.2-2_i386.deb
libreoffice4.0-ure_4.0.1.2-2_i386.deb
libreoffice4.0-writer_4.0.1.2-2_i386.deb
nigel@nigel-AOA150 ~ $ ls -a ~/Desktop/delete-me/langpack/LibreOffice_4.0.1.2_Linux_x86_deb_langpack_en-GB/DEBS
libobasis4.0-en-gb_4.0.1.2-2_i386.deb
libobasis4.0-en-gb-base_4.0.1.2-2_i386.deb
libobasis4.0-en-gb-calc_4.0.1.2-2_i386.deb
libobasis4.0-en-gb-math_4.0.1.2-2_i386.deb
libobasis4.0-en-gb-res_4.0.1.2-2_i386.deb
libobasis4.0-en-gb-writer_4.0.1.2-2_i386.deb
libreoffice4.0-en-gb_4.0.1.2-2_i386.deb
nigel@nigel-AOA150 ~ $ ls -a ~/Desktop/delete-me/helppack/LibreOffice_4.0.1.2_Linux_x86_deb_helppack_en-GB/DEBS
.  ..  libobasis4.0-en-gb-help_4.0.1.2-2_i386.deb
nigel@nigel-AOA150 ~ $ cat /etc/apt/sources.list; for X in /etc/apt/sources.list.d/*; do echo; echo; echo "** $X:"; echo; cat $X; done
# deb cdrom:[Peppermint 2 - i386 (20110427)]/ natty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://mirror01.th.ifl.net/ubuntu/ natty main restricted
deb-src http://mirror01.th.ifl.net/ubuntu/ natty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://mirror01.th.ifl.net/ubuntu/ natty-updates main restricted
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://mirror01.th.ifl.net/ubuntu/ natty universe
deb-src http://mirror01.th.ifl.net/ubuntu/ natty universe
deb http://mirror01.th.ifl.net/ubuntu/ natty-updates universe
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://mirror01.th.ifl.net/ubuntu/ natty multiverse
deb-src http://mirror01.th.ifl.net/ubuntu/ natty multiverse
deb http://mirror01.th.ifl.net/ubuntu/ natty-updates multiverse
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://gg.archive.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
# deb-src http://gg.archive.ubuntu.com/ubuntu/ natty-backports main restricted universe multiverse
deb http://mirror01.th.ifl.net/ubuntu/ natty-security main restricted
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-security main restricted
deb http://mirror01.th.ifl.net/ubuntu/ natty-security universe
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-security universe
deb http://mirror01.th.ifl.net/ubuntu/ natty-security multiverse
deb-src http://mirror01.th.ifl.net/ubuntu/ natty-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu natty partner
deb-src http://archive.canonical.com/ubuntu natty partner
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
deb http://extras.ubuntu.com/ubuntu natty main
deb-src http://extras.ubuntu.com/ubuntu natty main
** /etc/apt/sources.list.d/google-chrome.list:
### THIS FILE IS AUTOMATICALLY CONFIGURED ###
# You may comment out this entry, but any other modifications may be lost.
deb http://dl.google.com/linux/chrome/deb/ stable main
** /etc/apt/sources.list.d/peppermint.list:
deb http://ppa.launchpad.net/kendalltweaver/peppermint/ubuntu natty main
# deb-src http://ppa.launchpad.net/kendalltweaver/peppermint/ubuntu natty main
deb http://ppa.launchpad.net/chromium-daily/stable/ubuntu natty main
# deb-src http://ppa.launchpad.net/chromium-daily/stable/ubuntu natty main
** /etc/apt/sources.list.d/peppermint.list.save:
#deb-src http://ppa.launchpad.net/kendalltweaver/peppermint/ubuntu natty main
#deb-src http://ppa.launchpad.net/chromium-daily/stable/ubuntu natty main
** /etc/apt/sources.list.d/webupd8team-jupiter-natty.list:
deb http://ppa.launchpad.net/webupd8team/jupiter/ubuntu natty main
deb-src http://ppa.launchpad.net/webupd8team/jupiter/ubuntu natty main
