Author Topic: Easy printer installation wanted.  (Read 756 times)
Offline goldtopia
  • Full Member
    • Motley Minstrels
« on: April 10, 2013, 01:29:47 pm »
Trying to install a Canon printer is driving me up the wall. I tried the instructions but no joy . So I want to buy a fully compatible HP printer that I can install without a load of hassle so that I can live a peaceful life. I saw somewhere on the forum mention of a double sided recommended HP printer, but I don't remember what it was. What was it and is it really hassle free ?
Bill.O
Re: Easy printer installation wanted.
« Reply #1 on: April 10, 2013, 04:33:39 pm »
Most HP printers will work out of the box, but if you want to be 100% sure ..
check which version of hplip you have:
dpkg -l | grep hplip
should tell you.
Then before buying go here:
http://hplipopensource.com/hplip-web/supported_devices/index.html
enter the printer model you're thinking of .. and check the minimum hplip version that's necessary for it.
