Author Topic: TL-WN725N nano recognised but not connecting  (Read 25568 times)
Offline saulus
« on: April 17, 2013, 01:13:23 pm »
hi anyone, my new netbook has bugs so went out and got a nano TL - WN725N wifi thingy and it is being recognised but not connecting to the router?????? can anyone help? i installed the latest in windows ubuntu.... thanks
Re: TL-WN725N nano recognised but not connecting
« Reply #1 on: April 17, 2013, 03:19:55 pm »
Can you open a terminal (Ctrl+Alt+T) and send the output from these commands:
lsusb
sudo lshw -C network
iwconfig
iwlist scanning
rfkill list
If it will make it easier .. connect to your router with an ethernet cable whilst doing this.
Offline saulus
« Reply #2 on: April 17, 2013, 03:43:13 pm »
Hi, thanks for your reply, since posting the nano has been recognized, but then crashes and not connecting again. did as you instructed and got this back
paul@ubuntu:~$ lsusb
Bus 001 Device 011: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN
paul@ubuntu:~$ sudo lshw -C network
[sudo] password for paul:
  *-network
       product: RTL8188CE 802.11b/g/n WiFi Adapter
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 01
       width: 64 bits
       configuration: driver=rtl8192ce latency=0
       resources: irq:16 ioport:e000(size=256) memory:dfe00000-dfe03fff
  *-network
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 05
       serial: 8c:89:a5:05:eb:51
       capacity: 100Mbit/s
       width: 64 bits
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.1.31 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:42 ioport:d000(size=256) memory:dfd04000-dfd04fff memory:dfd00000-dfd03fff
  *-network
       physical id: 1
       bus info: usb@1:2
       logical name: wlan0
       serial: a0:f3:c1:1a:18:b1
       configuration: broadcast=yes driver=rtl8192cu driverversion=3.5.0-27-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
paul@ubuntu:~$ iwconfig
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
paul@ubuntu:~$ iwlist scanning
wlan0     No scan results
paul@ubuntu:~$ rfkill list
8: phy9: Wireless LAN
   Soft blocked: no
   Hard blocked: no
paul@ubuntu:~$
« Reply #3 on: April 17, 2013, 04:18:04 pm »
Just getting the correct driver now .. but whilst you wait, install linux-headers-generic and build-essential by running this command:
You MUST have an active internet connection for the above command to work.
Offline saulus
« Reply #4 on: April 17, 2013, 04:30:49 pm »
thanks again, have put that command in but got this back
paul@ubuntu:~$ sudo apt-get install linux-headers-generic build-essential
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
« Reply #5 on: April 17, 2013, 04:44:07 pm »
Make sure ALL package managers are closed .. then run it again
Package managers include
Update Manager
Software Centre
Synaptic (if installed)
Or you could just reboot, and not open any of the above whilst running the command ;)
« Reply #6 on: April 17, 2013, 04:47:36 pm »
OK, be SURE to run the command in my last but one response whilst connected to your router with an ethernet cable BEFORE running these commands.
Here it is again, just in case (won't hurt if you run it again .. it will just tell you they are already installed):
You'll still need an active internet connection for the "wget" command below .. so propbably best to stay connected to the router until you've finished running the commands below.
I must add, I haven't tested this build against a 3.5 kernel, but they compile against the 3.2 kernel .. and they're either going to compile or not, so can't do any harm ;)
Open a terminal (Ctrl+Alt+T) and run these commands in sequence.
mkdir ~/TL-WN725N_driver
cd ~/TL-WN725N_driver
wget https://dl.dropboxusercontent.com/u/11876059/rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105.tar.gz
tar -xvf rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105.tar.gz
cd ~/TL-WN725N_driver/rtl8188C_8192C_usb_linux_v3.4.4_4749.20121105
make
sudo make install
sudo modprobe -r rtl8192cu
sudo modprobe 8192cu
Did wireless spring to life ?
If so .. check it survives a reboot.
Offline saulus
« Reply #7 on: April 17, 2013, 06:51:40 pm »
did as you commanded and all went well except for the last line which came up not found. connecting the tk-link and it connected. did a reboot and am using it now. would love if i could buy you a drink or somit (i'm irish) for going out of your way for me, your THE JOB...... thanks a mill
« Reply #8 on: April 17, 2013, 07:04:24 pm »
Your "thanks" is enough for me, glad to be of service .. and you're welcome :)
Offline saulus
« Reply #9 on: April 17, 2013, 07:58:41 pm »
mark, sorry to say that it is still going into search mode and not connecting, maybe i do have to do the last bit that failed?????
« Reply #10 on: April 17, 2013, 10:52:05 pm »
Can you post the output from:
modinfo 8192cu
lsmod | grep 8192
