Author Topic: Accounting software  (Read 1870 times)
Offline Toonman
Accounting software
« on: April 24, 2013, 07:17:38 am »
Hello.
I am looking for Linux accounting software.  I would prefer something simple that I can generate invoices from and have integrated database, printing labela etc.  Any suggestions.
Thanks
Re: Accounting software
« Reply #1 on: April 24, 2013, 12:21:51 pm »
GNUcash can do all that, but there's (IMHO) quite a steep learning curved attached.
Then again, I suppose that can be said of any accounting software.
Offline Toonman
« Reply #2 on: April 24, 2013, 04:19:13 pm »
Cheers Mark
I will give it a go but I think it could be a case of dusting of horrible vista again.  :(
Offline Toonman
« Reply #3 on: April 24, 2013, 04:22:45 pm »
On second thoughts.  Having had a quick look, it seems it may be OK.
I will give it a chance.
« Reply #4 on: April 24, 2013, 04:51:16 pm »
It's a good package .. just needs a bit of homework to get it set up ;)
Once set up it does the job admirably.
GNUcash documentation:-
http://www.gnucash.org/docs.phtml
Offline Toonman
« Reply #5 on: April 24, 2013, 04:54:53 pm »
Thanks for the link.  :)
Offline Mad Penguin
    • Linux in the UK
« Reply #6 on: April 24, 2013, 05:57:18 pm »
I can recommend Kashflow.com or Xero.com - you will find they do a *much* better job than any accounting software you will be able to download .. not free, but then not that expensive in the grand scale of things ..  :)
Offline Toonman
« Reply #7 on: April 25, 2013, 06:31:56 am »
Thanks MP. I will check them out.
