Author Topic: Mint 14.1 Not recognizing my Andriod device.  (Read 30862 times)
Offline Toonman
« on: April 28, 2013, 07:46:45 am »
Just moved to Mint 14.1 to see if I can get any more life out of my laptop.  Ubuntu was starting to misbehave in many ways and I really was sick of Unity. Mint seems to be flying along. The thing is  I use HSPA on my Andriod mobile for the Internet.  It's very fast and serves me well.  With Ubuntu my mobile was recognized as a USB drive or a router instantly (when connected by lead).  Now, Mint can see the wireless on my mobile and connect but in is not recognizing it as a device at all for file transfer or router when connected by a a usb lead.
Can you help?
Re: Mint 14.1 Not recognizing my Andriod device.
« Reply #1 on: April 28, 2013, 11:06:04 am »
IIRC diidn't Mint do something weird with the .gvfs directory ?
When you plug the device in by USB, what's the output from:
dmesg | tail -n 40
and is there anything listed at
/run/users/<your-username>/gvfs
Emegra
  • Guest
« Reply #2 on: April 28, 2013, 11:14:43 am »
Yeah they moved it location to /run/user/your-user-name/gvfs
Offline SeZo
« Reply #3 on: April 28, 2013, 12:02:48 pm »
See if gvfs-mtp is installed
Offline Toonman
« Reply #4 on: April 28, 2013, 05:06:50 pm »
Here is the output Mark
dmesg | tail -n 40
[   18.051378] cfg80211: Updating information on frequency 5640 MHz for a 20 MHz width channel with regulatory rule:
[   18.051380] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051383] cfg80211: Updating information on frequency 5660 MHz for a 20 MHz width channel with regulatory rule:
[   18.051385] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051388] cfg80211: Updating information on frequency 5680 MHz for a 20 MHz width channel with regulatory rule:
[   18.051390] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051392] cfg80211: Updating information on frequency 5700 MHz for a 20 MHz width channel with regulatory rule:
[   18.051395] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051397] cfg80211: Updating information on frequency 5745 MHz for a 20 MHz width channel with regulatory rule:
[   18.051400] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051402] cfg80211: Updating information on frequency 5765 MHz for a 20 MHz width channel with regulatory rule:
[   18.051405] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051407] cfg80211: Updating information on frequency 5785 MHz for a 20 MHz width channel with regulatory rule:
[   18.051410] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051412] cfg80211: Updating information on frequency 5805 MHz for a 20 MHz width channel with regulatory rule:
[   18.051415] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051417] cfg80211: Updating information on frequency 5825 MHz for a 20 MHz width channel with regulatory rule:
[   18.051419] cfg80211: 5460000 KHz - 5860000 KHz @ 40000 KHz), (N/A mBi, 3000 mBm)
[   18.051561] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
[   18.057616] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input12
[   18.067718] ieee80211 phy0: >Selected rate control algorithm 'minstrel_ht'
[   18.068991] ath5k: phy0: Atheros AR5414 chip found (MAC: 0xa2, PHY: 0x61)
[   18.111005] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   18.111860] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   20.139926] init: plymouth-stop pre-start process (1546) terminated with status 1
[   25.649325] wlan0: authenticate with 90:c1:15:76:7e:fa
[   25.657791] wlan0: direct probe to 90:c1:15:76:7e:fa (try 1/3)
[   25.860047] wlan0: send auth to 90:c1:15:76:7e:fa (try 2/3)
[   25.862602] wlan0: authenticated
[   25.868261] wlan0: associate with 90:c1:15:76:7e:fa (try 1/3)
[   25.870756] wlan0: RX AssocResp from 90:c1:15:76:7e:fa (capab=0x431 status=0 aid=1)
[   25.871492] wlan0: associated
[   25.871908] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   29.472893] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[  106.641879] sd 5:0:0:2: >[sdd] 31268864 512-byte logical blocks: (16.0 GB/14.9 GiB)
[  106.651873] sd 5:0:0:2: >[sdd] No Caching mode page present
[  106.651880] sd 5:0:0:2: >[sdd] Assuming drive cache: write through
[  106.671867] sd 5:0:0:2: >[sdd] No Caching mode page present
[  106.671874] sd 5:0:0:2: >[sdd] Assuming drive cache: write through
[  106.677921]  sdd: sdd1
« Reply #5 on: April 28, 2013, 06:08:43 pm »
If this is the phone, it appears that it IS being mounted as /dev/sdd1
First try SeZo's idea:
sudo apt-get install gvfs-mtp
Then see if anything is mounted at /run/users/<your-username>/gvfs
and post the output from:
mount
Offline Toonman
« Reply #6 on: April 28, 2013, 06:41:05 pm »
I tried Sezo's idea, this is what I got.
Reading package lists... Done
Building dependency tree
E: Unable to locate package gvfs-mtp
« Reply #7 on: April 28, 2013, 06:46:00 pm »
I think what you want is the mtpfs package.
Offline Toonman
« Reply #8 on: April 28, 2013, 07:28:54 pm »
With mtpfs
E: Unable to locate package gvfs-mtpfs
« Reply #9 on: April 28, 2013, 07:44:28 pm »
No just:
sudo apt-get install mtpfs
You haven't answered my earlier questions .. any particular reason why ?
Offline Toonman
« Reply #10 on: April 28, 2013, 07:48:45 pm »
"You haven't answered my earlier questions .. any particular reason why ?"
Sorry.  I dont know what I have missed Mark.  ???
Offline Toonman
« Reply #11 on: April 28, 2013, 07:50:36 pm »
Just input the above code.
« Reply #12 on: April 28, 2013, 08:00:03 pm »
Quote from: Me
mount
Offline Toonman
« Reply #13 on: April 28, 2013, 08:05:13 pm »
mount
/dev/sda5 on / type ext4 (rw,errors=remount-ro)
Sorry, there you go. :)
gvfsd-fuse on /run/user/adammaureen/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=adammaureen)
/dev/sdf5 on /media/adammaureen/Seagate type vfat (rw,nosuid,nodev,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush,uhelper=udisks2)
« Reply #14 on: April 28, 2013, 08:12:59 pm »
Was that with the phone plugged in ?
Unplug the phone from the USB socket .. Plug the phone back in, then send the output from:
dmesg | tail -n 40
mount
ls -a /run/user/adammaureen/gvfs
Can you also mention the phone make/model/OS
When you say it worked in Ubuntu .. which version, and what exactly happened when you plugged it in that isn't happening now ?
