Author Topic: Mint 14.1 Not recognizing my Andriod device.  (Read 24151 times)
Offline Toonman
Re: Mint 14.1 Not recognizing my Andriod device.
« Reply #30 on: April 30, 2013, 06:22:50 am »
Thanks. Give me a couple of days.  Been called away again.
Offline BkS
  • BkS Media Founder
« Reply #31 on: May 02, 2013, 05:51:10 am »
If my memory serves me correct, for me to mount my SGS3 / N7 in Ubuntu/Mint I had enable mass storage via USB settings on the phone / tablet, or enable UMS mode. Having had enough of the issues, I said f*** it, and just installed Samba on my Android devices. Much simpler, and easier.
Samba for Android - Google Play Store
Though it's not "THE" solution you're looking for, it is "a" solution. :)
« Last Edit: May 02, 2013, 05:53:41 am by BkS »
Offline Toonman
« Reply #32 on: May 09, 2013, 07:47:33 am »
Sorry for the lengthy delay.  I have been working away.
Output
uname -a
Linux adammaureen-EQUIUM-L350 3.6.0-030600-generic #201209302035 SMP Mon Oct 1 00:43:10 UTC 2012 i686 i686 i686 GNU/Linux
Offline Toonman
« Reply #33 on: May 09, 2013, 07:49:26 am »
Output when phone plugged back ijn.
dmesg | tail -n 25
[ 2093.385048] usb 2-3: can't set HNP mode: -32
[ 2093.500057] usb 2-3: new high-speed USB device number 7 using ehci_hcd
[ 2093.521049] usb 2-3: Dual-Role OTG device on non-HNP port
[ 2093.521165] usb 2-3: can't set HNP mode: -32
[ 2093.636060] usb 2-3: new high-speed USB device number 8 using ehci_hcd
[ 2093.657049] usb 2-3: Dual-Role OTG device on non-HNP port
[ 2093.657169] usb 2-3: can't set HNP mode: -32
[ 2093.660064] hub 2-0:1.0: unable to enumerate USB device on port 3
[ 2093.928073] usb 6-1: new full-speed USB device number 2 using uhci_hcd
[ 2094.071080] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.098081] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.100093] usb 6-1: can't set HNP mode: -32
[ 2094.212061] usb 6-1: new full-speed USB device number 3 using uhci_hcd
[ 2094.355079] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.380080] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.382075] usb 6-1: can't set HNP mode: -32
[ 2094.492072] usb 6-1: new full-speed USB device number 4 using uhci_hcd
[ 2094.523077] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.550080] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.552092] usb 6-1: can't set HNP mode: -32
[ 2094.664068] usb 6-1: new full-speed USB device number 5 using uhci_hcd
[ 2094.694079] usb 6-1: not running at top speed; connect to a high speed hub
[ 2094.721078] usb 6-1: Dual-Role OTG device on non-HNP port
[ 2094.723076] usb 6-1: can't set HNP mode: -32
[ 2094.724083] hub 6-0:1.0: unable to enumerate USB device on port 1
« Reply #34 on: May 09, 2013, 05:53:24 pm »
I've asked this multiple times and you haven't answered yet .. Which version of Ubuntu did it work in ?
Offline Toonman
« Reply #35 on: May 10, 2013, 06:34:47 am »
My apologies I thought I had.
UBUNTU 12.10   Also The Andriod operating system is 2.3 NOT 4.1 as I said in a previous post.
Thanks
« Reply #36 on: May 10, 2013, 11:57:56 am »
Is this the SAME PC that it previously worked on ?
Seems odd that it would work on Ubuntu 12.10 but not Mint 14 as they use the same kernel series and the same(ish) repos .. so I'm trying to figure out if anything else has changed ?
Offline Toonman
« Reply #37 on: May 10, 2013, 02:10:54 pm »
Yes it's the same PC.  Even more odd is the fact that I have now plugged in my Samsung Galaxy note 2 and it is instantly recognized.  There have been no problems until the last week or so.  No Andriod updates and as far as I know None for Mint. Now here is the really interesting news......it works with my netbook with Peppermint 3!
« Reply #38 on: May 10, 2013, 02:33:18 pm »
Just for comparison, can you plug it into the Peppermint 3 netbook, then send the output from:
dmesg | tail -n 30
Offline Toonman
« Reply #39 on: May 10, 2013, 02:38:36 pm »
This is in media transfer mode NOT USB network sharing
[ 1087.856919] usb 5-1: can't set HNP mode: -32
[ 1087.968144] usb 5-1: new full-speed USB device number 19 using uhci_hcd
[ 1088.111060] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.134075] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.136107] usb 5-1: can't set HNP mode: -32
[ 1088.248076] usb 5-1: new full-speed USB device number 20 using uhci_hcd
[ 1088.279149] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.305149] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.307141] usb 5-1: can't set HNP mode: -32
[ 1088.476139] usb 5-1: new full-speed USB device number 21 using uhci_hcd
[ 1088.506262] usb 5-1: not running at top speed; connect to a high speed hub
[ 1088.533264] usb 5-1: Dual-Role OTG device on non-HNP port
[ 1088.535258] usb 5-1: can't set HNP mode: -32
[ 1088.536280] hub 5-0:1.0: unable to enumerate USB device on port 1
[ 1145.768129] usb 2-2: new high-speed USB device number 21 using ehci_hcd
[ 1145.901320] usb 2-2: New USB device found, idVendor=04e8, idProduct=6860
[ 1145.901332] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1145.901340] usb 2-2: Product: SAMSUNG_Android
[ 1145.901347] usb 2-2: Manufacturer: SAMSUNG
[ 1145.901353] usb 2-2: SerialNumber: 4df735d23b4acfa5
[ 1145.902754] cdc_acm 2-2:1.1: This device cannot do calls on its own. It is not a modem.
[ 1145.902920] cdc_acm 2-2:1.1: ttyACM0: USB ACM device
[ 1401.361346] usb 2-2: USB disconnect, device number 21
[ 1401.696110] usb 2-2: new high-speed USB device number 22 using ehci_hcd
[ 1401.829270] usb 2-2: New USB device found, idVendor=04e8, idProduct=6864
[ 1401.829282] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1401.829289] usb 2-2: Product: SAMSUNG_Android
[ 1401.829296] usb 2-2: Manufacturer: SAMSUNG
[ 1401.829303] usb 2-2: SerialNumber: 4df735d23b4acfa5
[ 1401.832412] rndis_host 2-2:1.0: usb0: register 'rndis_host' at usb-0000:00:1d.7-2, RNDIS device, 02:00:61:37:62:30
« Reply #40 on: May 10, 2013, 02:42:58 pm »
On the netbook, did it not work on some USB ports but work on the others ?
Offline Toonman
« Reply #41 on: May 10, 2013, 02:45:33 pm »
No on the netbook it works on all three usb ports.
« Reply #42 on: May 10, 2013, 02:55:22 pm »
Have you got a USB hub ? .. if so, try connecting to the Mint machine with and without that in between.
Offline Toonman
« Reply #43 on: May 10, 2013, 03:00:38 pm »
No hub, need a new one.  Will get one at the weekend.
« Reply #44 on: May 10, 2013, 03:07:11 pm »
Do you know how to boot into the older kernel, so we can remove 3.6 ?
I have a feeling this is still related to that bug report I mentioned earlier .. we really need to get Mint to get the 3.5.0-19.30 kernel from Ubuntu updates (which Ubuntu would have installed as an update).
Are you SURE Ubuntu was 12.10 and not 12.04 ?
« Last Edit: May 10, 2013, 03:11:46 pm by Mark Greaves (PCNetSpec) »
