Author Topic: Mint 14.1 Not recognizing my Andriod device.  (Read 24518 times)
Offline Toonman
Re: Mint 14.1 Not recognizing my Andriod device.
« Reply #45 on: May 10, 2013, 03:10:04 pm »
Right.  I have re-read this thread and gone through all the terminal commands.  I looked at BKS's post and checked the mass storage box.  For some reason this works over file transfer.  The thing is I never checked file transfer mode over Mass storage it was just an automatic command.  Why this has happened I dont know.  I never had this issue before.  It's strange it works in File transfer mode on Peppermint but stopped working in Mint.
So it is now resolved.  Thanks to everyone who has helped.
« Reply #46 on: May 10, 2013, 03:13:26 pm »
Cool .. is it working as a modem as well as a mass storage device ?
Offline Toonman
« Reply #47 on: May 10, 2013, 03:26:10 pm »
OK.  I was a bit excited about it working.  It's not.  The phone now has a check box active for usb mass storage and file transfer that could not be 'checked' before.  I now can check it but nothing happens.  No modem and not recognized in 'Disks'.  DAMN!
« Reply #48 on: May 10, 2013, 03:28:21 pm »
Offline Toonman
« Reply #49 on: May 10, 2013, 03:30:29 pm »
Ha.  :)  No I dont know how to boot into an older kernel.
« Reply #50 on: May 10, 2013, 03:37:10 pm »
Shut down your PC .. turn ON your PC, and immediately hit and hold the "Shift" key until you are presented with the GRUB menu.
In the GRUB menu, use the down arrow key to select "Previous Linux Versions" and hit enter.
In the next menu, select the top option (already selected) and hit enter to boot.
Once booted, post the output from:
uname -a
dpkg -l | grep 3.6.0
You're also selectively answering my questions again ;)
Are you SURE the working Ubuntu version was 12.10 (quantal) and not 12.04 (precise) ?
« Last Edit: May 10, 2013, 03:43:11 pm by Mark Greaves (PCNetSpec) »
Offline Toonman
« Reply #51 on: May 10, 2013, 04:11:12 pm »
Sorry.  I was wrong it was 12.04.  I am just worn out with work at the moment and I am making mistakes.   :-[
First
Linux adammaureen-EQUIUM-L350 3.5.0-17-generic #28-Ubuntu SMP Tue Oct 9 19:32:08 UTC 2012 i686 i686 i686 GNU/Linux
Second
ii  bamfdaemon                                  0.3.6-0ubuntu2                            i386         Window matching library - daemon
ii  evince-common                               3.6.0-0ubuntu2                            all          Document (PostScript, PDF) viewer - common files
ii  gcr                                         3.6.0-0ubuntu1                            i386         GNOME crypto services (daemon and tools)
ii  gir1.2-gmenu-3.0                            3.6.0-0ubuntu1                            i386         GObject introspection data for the GNOME menu library
ii  gir1.2-gnomebluetooth-1.0                   3.6.0-0ubuntu1                            i386         Introspection data for GnomeBluetooth
ii  gir1.2-gnomekeyring-1.0                     3.6.0-0ubuntu1                            i386         GNOME keyring services library - introspection data
ii  gir1.2-goa-1.0                              3.6.0-0ubuntu1.1                          i386         Introspection data for GNOME Online Accounts
ii  gir1.2-gtk-3.0                              3.6.0-0ubuntu3.2                          i386         GTK+ graphical user interface library -- gir bindings
ii  gir1.2-gtksource-3.0                        3.6.0-0ubuntu1                            i386         gir files for the GTK+ syntax highlighting widget
ii  gnome-desktop3-data                         3.6.0.1-0ubuntu2                          all          Common files for GNOME desktop apps
ii  gnome-icon-theme                            3.6.0-0ubuntu2                            all          GNOME Desktop icon theme (small subset)
ii  gnome-icon-theme-full                       3.6.0-0ubuntu2                            all          GNOME Desktop icon theme
ii  gnome-icon-theme-symbolic                   3.6.0-0ubuntu1                            all          GNOME desktop icon theme (symbolic icons)
ii  gsettings-desktop-schemas                   3.6.0-0ubuntu3                            all          GSettings deskop-wide schemas
ii  libbamf3-0:i386                             0.3.6-0ubuntu2                            i386         Window matching library - shared library
ii  libevdocument3-4                            3.6.0-0ubuntu2                            i386         Document (PostScript, PDF) rendering library
ii  libevview3-3                                3.6.0-0ubuntu2                            i386         Document (PostScript, PDF) rendering library - Gtk+ widgets
ii  libgail-3-0:i386                            3.6.0-0ubuntu3.2                          i386         GNOME Accessibility Implementation Library -- shared libraries
ii  libgck-1-0                                  3.6.0-0ubuntu1                            i386         Glib wrapper library for PKCS#11 - runtime
ii  libgcr-3-1                                  3.6.0-0ubuntu1                            i386         Library for Crypto UI related task - runtime
ii  libgcr-3-common                             3.6.0-0ubuntu1                            all          Library for Crypto UI related task - common files
ii  libgnome-bluetooth11                        3.6.0-0ubuntu1                            i386         GNOME Bluetooth tools - support library
ii  libgnome-desktop-3-4                        3.6.0.1-0ubuntu2                          i386         Utility library for loading .desktop files - runtime files
ii  libgnome-keyring-common                     3.6.0-0ubuntu1                            all          GNOME keyring services library - data files
ii  libgnome-keyring0:i386                      3.6.0-0ubuntu1                            i386         GNOME keyring services library
ii  libgnome-menu-3-0                           3.6.0-0ubuntu1                            i386         GNOME implementation of the freedesktop menu specification
ii  libgnomekbd-common                          3.6.0-0ubuntu1                            all          GNOME library to manage keyboard configuration - common files
ii  libgnomekbd8                                3.6.0-0ubuntu1                            i386         GNOME library to manage keyboard configuration - shared library
ii  libgoa-1.0-0:i386                           3.6.0-0ubuntu1.1                          i386         library for GNOME Online Accounts
ii  libgoa-1.0-common                           3.6.0-0ubuntu1.1                          all          library for GNOME Online Accounts - common files
ii  libgtk-3-0:i386                             3.6.0-0ubuntu3.2                          i386         GTK+ graphical user interface library
ii  libgtk-3-bin                                3.6.0-0ubuntu3.2                          i386         programs for the GTK+ graphical user interface library
ii  libgtk-3-common                             3.6.0-0ubuntu3.2                          all          common files for the GTK+ graphical user interface library
ii  libgtksourceview-3.0-0:i386                 3.6.0-0ubuntu1                            i386         shared libraries for the GTK+ syntax highlighting widget
ii  libgtksourceview-3.0-common                 3.6.0-0ubuntu1                            all          common files for the GTK+ syntax highlighting widget
ii  libgweather-3-1                             3.6.0-0ubuntu1                            i386         GWeather shared library
ii  libgweather-common                          3.6.0-0ubuntu1                            all          GWeather common files
ii  libyelp0                                    3.6.0-0ubuntu1                            i386         Library for the GNOME help browser
ii  linux-headers-3.6.0-030600                  3.6.0-030600.201209302035                 all          Header files related to Linux kernel version 3.6.0
ii  linux-headers-3.6.0-030600-generic          3.6.0-030600.201209302035                 i386         Linux kernel headers for version 3.6.0 on 32 bit x86 SMP
ii  linux-image-3.6.0-030600-generic            3.6.0-030600.201209302035                 i386         Linux kernel image for version 3.6.0 on 32 bit x86 SMP
ii  linux-image-extra-3.6.0-030600-generic      3.6.0-030600.201209302035                 i386         Linux kernel image for version 3.6.0 on 32 bit x86 SMP
ii  mousetweaks                                 3.6.0-0ubuntu2                            i386         mouse accessibility enhancements for the GNOME desktop
ii  simple-scan                                 3.6.0-0ubuntu1                            i386         Simple Scanning Utility
ii  vino                                        3.6.0-0ubuntu1.1                          i386         VNC server for GNOME
ii  xserver-xorg-video-savage                   1:2.3.6-0ubuntu1                          i386         X.Org X server -- Savage display driver
ii  xserver-xorg-video-trident                  1:1.3.6-0ubuntu2                          i386         X.Org X server -- Trident display driver
ii  yelp                                        3.6.0-0ubuntu1                            i386         Help browser for GNOME
ii  yelp-xsl                                    3.6.0-0ubuntu1                            all          XSL stylesheets for the yelp help browser
« Reply #52 on: May 10, 2013, 04:20:36 pm »
OK, run:
sudo apt-get remove linux-headers-3.6.0-030600 linux-headers-3.6.0-030600-generic linux-image-3.6.0-030600-generic linux-image-extra-3.6.0-030600-generic
(wait for that command to leave you back at an $ prompt)
then reboot normally (without holding shift), and hopefully it will boot into 3.5.0-17 .. you can check this by running:
uname -a
again.
If you are at 3.5.0-17 after the normal reboot, do this -
Launch the Mint Updater .. Go to Edit>Preferences .. tick "Safe" and "Visible" for all 5 categories.
Apply, and you should now hopefully be able to see and select the 3.5.0-19 kernel update.
If it DID upgrade the kernel to 3.5.0-19 .. REBOOT.
Check it booted into 3.5.0-19 with:
uname -a
again.
If "uname -a" says you're now running 3.5.0-19 .. try your phone now.
« Last Edit: May 10, 2013, 04:51:36 pm by Mark Greaves (PCNetSpec) »
Offline Toonman
« Reply #53 on: May 10, 2013, 04:29:41 pm »
Replying from my Andriod phone as the computer is hanging at the promt after reboot.
« Reply #54 on: May 10, 2013, 04:31:19 pm »
Do what you did before .. hold shift etc. and select the 3.5.0-17 kernel to boot into.
if it boots, run:
sudo update-grub
and post the output.
« Last Edit: May 10, 2013, 04:34:47 pm by Mark Greaves (PCNetSpec) »
Offline Toonman
« Reply #55 on: May 10, 2013, 04:46:50 pm »
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-3.5.0-17-generic
Found initrd image: /boot/initrd.img-3.5.0-17-generic
Found memtest86+ image: /boot/memtest86+.bin
Found Windows Vista (loader) on /dev/sda2
done
« Reply #56 on: May 10, 2013, 04:48:16 pm »
Reboot and see if it boots normally now.
Offline Toonman
« Reply #57 on: May 15, 2013, 06:43:26 am »
Nup.  keeps hanging on boot and when I force a restart it will not recognize my phone.  There is now a folder on my desktop which is named Kernel 3.6.
« Reply #58 on: May 15, 2013, 06:28:22 pm »
Try  this ..
are there any kernel updates listed ?
Offline Toonman
« Reply #59 on: May 16, 2013, 07:17:42 am »
Done that showed 5 updates for Kernel 3.5.
Still doesn't work and worst still my other phone that did work now won't.
This is a right so and so to fix.
