Author Topic: [SOLVED] Trying to install an emulator  (Read 8029 times)
Offline pooky2483
Re: Trying to install an emulator
« Reply #15 on: May 14, 2013, 12:21:35 pm »
VICE and .prg files ..
see if anything here helps:-
http://sleepingelephant.com/ipw-web/bulletin/bb/viewtopic.php?p=6450&sid=7ede0c1b847222dc533212dd1d25eb52
I managed to get one loaded yesterday but for the life of me , now I can't remember how I did it.
So... I will have a look at the link you gave and see what I can do...
Re: [SOLVED] Trying to install an emulator
« Reply #16 on: May 14, 2013, 01:03:14 pm »
Heh .. I do that a lot too ;)
If it's important .. take notes as you go.
« Last Edit: May 14, 2013, 01:07:22 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #17 on: May 14, 2013, 08:53:20 pm »
Got it...
