Author Topic: lost my sticky note  (Read 7168 times)
Re: lost my sticky note
« Reply #15 on: May 23, 2013, 05:36:37 pm »
So what was it called ? .. you're not giving me any clues that will steer me to the specific application, and without knowing that I can't find out where it stores the notes.
« Last Edit: May 23, 2013, 05:39:30 pm by Mark Greaves (PCNetSpec) »
Offline SeZo
« Reply #16 on: May 23, 2013, 06:43:52 pm »
file:///usr/share/omf-langpack/stickynotes_applet/stickynotes_applet-en_GB.omf
I think Mako might be talking about (in first post) the Gnome2 version of Sticky Notes (Ubuntu 10.04)
cat ~/.gnome2/stickynotes_applet
This should show the content of the data file (xml).
Apparently Tomboy can import this data.
Offline mako6
  • Full Member
« Reply #17 on: May 24, 2013, 02:06:40 pm »
Yeah, that's it, thanks. Though it has truncated the top of the note. How do I reinstall it?
Offline SeZo
« Reply #18 on: May 24, 2013, 04:54:57 pm »
According to this page it looks like it is part of the gnome-applets package.
To re-install (but I would try to re add it to the panel first):
sudo apt-get install gnome-applets
Then to add to the panel, right click on the place you want the Sticky notes applet to appear, select Add to panel..., Sticky notes.
It will appear as a yellow icon that looks like a block of post-it notes.
Offline mako6
  • Full Member
« Reply #19 on: May 24, 2013, 05:55:27 pm »
Great. Thanks. It's back. Completely forgot where and how you got those applets. Duh. Thought it was relatively simple, but then sometimes so am I.
