Author Topic: PeppermintOS Three on an Acer Aspire ZG5 - Cursor Freeze  (Read 15756 times)
Offline freddie
« on: June 01, 2013, 07:28:39 am »
CURSOR FREEZE PROBLEM
I've been running PP3 on my AA1 for a while now and have all the updates loaded.
I have Firefox 21.0
and Thunderbird 17.0.6
But running them together I have recently found that my session usually ends with the cursor freezing - usually in Firefox but it can be Thunderbird. I don't recall this happening before I started doing the regular updates.
F7 doesn't clear it,
I am a bit of a fast and furious typist, so I wondered if it is something like the speaker - where F8 turns it off, but to turn it on you need to click on the volume icon and unmute the speaker.
I wondered if you had any ideas?
Re: PeppermintOS Three on an Acer Aspire ZG5 - Cursor Freeze
« Reply #1 on: June 01, 2013, 11:43:21 am »
When it next freezes .. can you hit Ctrl+Alt+T to open a terminal and run:
free -m
and post the output (I only really need the line that starts with Swap:)
Can you try using Chromium+Thunderbird instead of firefox and see if it still does it.
Offline SeZo
« Reply #2 on: June 01, 2013, 01:28:29 pm »
Is this AA1 with SSD?
Is the disk activity LED solid green?
If so then you are suffering from disk write lag.
Try moving Firefox cache into memory:
Firefox:
go to: about:config
filter: cache.
Set:
browser.cache.disk.enable false
browser.cache.memory.enable true
Check status:
about:cache
See if that makes any difference.
Offline freddie
« Reply #3 on: June 01, 2013, 01:43:33 pm »
Thanks Mark and SeZo. Will wait and see at the next freeze.
SeZo - Yes - SSD - have now updated my profile
Offline freddie
« Reply #4 on: June 02, 2013, 09:13:53 pm »
Froze in Thunderbird (no tabs), with Mozilla the only other active program (and 2 tabs open).
Disk light was solid for a few seconds after the freeze, then went out.
free -m gave swap 497 18 479
I did note the other readings if you want them
« Reply #5 on: June 02, 2013, 10:04:37 pm »
Does the mouse free up again when the green disk activity light goes out ?
Offline freddie
« Reply #6 on: June 02, 2013, 10:22:34 pm »
No. The thing is so seized up that I was amazed I could rouse the Terminal.
Shutting down is a heck of a problem too
« Reply #7 on: June 02, 2013, 11:46:52 pm »
OK, first of all if you can open a terminal you can shut down with:
sudo shutdown -P now
Secondly .. what happens if you unload the psmouse driver, then reload it:
sudo modprobe -r psmouse
sudo modprobe psmouse
does the mouse come back to life ?
BTW, I'm going to move these postings to their own topic after your next response .. though the issue IS related to Peppermint 3 and your AA1, it's not really related to the "installation" tutorial .. I'll also send you a link to the new topic by personal message (just in case you can't find it).
« Last Edit: June 02, 2013, 11:53:58 pm by Mark Greaves (PCNetSpec) »
Offline freddie
« Reply #8 on: June 03, 2013, 07:47:39 am »
Agree. I think it should be separate topic, but I wasn't sure where to put it - I couldn't find a separate Peppermint section
Been trying to bring the fault up for half an hour by being busy, but I think that's the problem - just have to be patient and at some time in normal use it comes up - just when you least want it!
Offline freddie
« Reply #9 on: June 05, 2013, 05:22:30 am »
I started with Thunderbird, and while it was active, this time the cursor froze in Firefox with two tabs open.
- BBC News
- Aljazeera - Turkish deputy PM apologises for 'excessive force'
(Oops! the cursor jumped in the middle of that line (and this) despite touchpad tap to click disabled)
http://www.aljazeera.com/news/europe/2013/06/20136411194960897.html
Disk light solid. Cursor frozen.
Unloaded mouse driver as you suggested; reloaded and all OK
Does that give any clues?
BTW that Aljazeera tab really hammers the disk light
« Last Edit: June 05, 2013, 05:25:14 am by freddie »
« Reply #10 on: June 05, 2013, 11:11:15 am »
Can you try something for me .. run this in a terminal:
syndaemon -i 1 -d
That will kill your touchpad whilst you're typing .. the touchpad will come back to life 1 second after you stop typing.
I just want to see if that makes any difference.
Be aware .. this will NOT survive a reboot, and will need entering again .. but if it improves things, we can make it load at bootup.
If (after running that) your mouse freezes .. try hitting any key, then waiting for 1 second .. does the touchpad start working again ?
Can you also confirm you made SeZo's suggested changes in Firefox, and what your "about:cache" page now says.
« Last Edit: June 05, 2013, 11:17:09 am by Mark Greaves (PCNetSpec) »
Offline freddie
« Reply #11 on: June 20, 2013, 10:06:51 am »
Hi
Sorry about the silence - been away...
1. CURSOR FREEZE IN FIREFOX
While away, when running Thunderbird, the AA1 cursor continued to freeze in Firefox (even with the cache mod) - with the disk light on solid.  Cursor reload worked OK.
Checking about:config it is still set to:
  browser.cache. disk.enable false
  browser.cache. memory.enable true
2. Cursor also repeatedly froze in Chromium - disk light on solid
3. KILL TOUCHPAD WHILE TYPNG
Thanks - that mod seems to work fine
How do I get to load at boot up?
« Reply #12 on: June 20, 2013, 11:00:15 am »
OK, syndaemon autostart ..
Open a terminal and run:
mkdir ~/.config/autostart
gedit ~/.config/autostart/touchpad-pause.desktop
When a blank file opens in gedit .. make it read:-
[Desktop Entry]
Type=Application
Name=Touchpad Pause
Comment=Make touchpad pause for 1 seconds whilst typing
Icon=input-touchpad
Exec=bash -c "syndaemon -i 1 -d"
Terminal=false
SAVE the file .. and reboot (or log off/on) to test.
does the mouse become active again if you just wait for the SSD activity light to stop being on solid ? .. may take a minute.
« Last Edit: February 09, 2014, 12:43:40 am by Mark Greaves (PCNetSpec) »
Offline freddie
« Reply #13 on: June 20, 2013, 04:27:57 pm »
Thanks
That all looked so easy, but when I tried to save it said:
Could not find the file /home/david/.config/auto…rt/touchpad-pause.desktop.
Please check that you typed the location correctly and try again.
Did a gremlin creep in somewhere?
The file seems to have that name, but even trying to save as with that name fails.
(Wish I wasn't still so virginal!)
« Reply #14 on: June 20, 2013, 04:38:39 pm »
Sorry, my mistake, I forgot the ~/.config/autostart directory doesn't exist by default, so needs to be created first.
I've fixed the above posting .. so reload this page, then try it again.
« Last Edit: June 20, 2013, 04:42:11 pm by Mark Greaves (PCNetSpec) »
