Future readers... Before continuing it would be a good idea to read these 2 topics:
http://linuxforums.org.uk/netbooks/acer-aspire-one-linpus-lite-firefox-web-browser-wont-open/and
http://linuxforums.org.uk/netbooks/install-firefox-6-on-an-acer-aspire-one-running-linpus-lite-linux/[END EDIT]
Outdated topic - see the link for installing Firefox 6 above
Acer has interwoven Firefox 2 with the rest of the system, that's why a quite unusual approach is required to install the newest version. The benefit of using an official release is a working update feature, which is disabled in the version already installed on the system.
Press
Alt+F2 to show the Run program window. Check Run in terminal and click Run, which opens a terminal. If you're not familiar with the Linux command line just follow the instructions step by step.
The easiest way is to simply paste the commands into the terminal with
Ctrl+Shift+V. Most of them will only give feedback if an error occurs.
Also remember that any line that starts with
sudo is going to ask for your root password (probably your user password)... when you type in the password you won't see anything (not even an *) , but it IS being entered, so type it in and hit enter.
The first command uses wget to download Firefox 3.6 from an official mirror.
Open a terminal and enter:
wget -N "http://download.mozilla.org/?product=firefox-3.6&os=linux&lang=en-GB"
Hit enter.
The next step extracts the just downloaded file and modifies a link to point to it. In a few cases a connection refused error message may be triggered by sudo, which is not an error but a bug in sudo and can be safely ignored.
In a terminal:
sudo tar -jxf firefox-3.6.tar.bz2 --directory /opt
sudo chown user -R /opt/firefox
sudo ln -fs /opt/firefox/firefox /usr/bin/firefox
remember to hit enter after each line.
The next step links all plug-ins (not to be confused with extensions) to it.
In a terminal:
sudo ln -s /usr/lib/mozilla/plugins/* /opt/firefox/plugins
Hit enter.
Launch the profile manager using the command below. Create a new profile, name it anything you like and select it. If you want to keep your bookmarks export them via the bookmark manager first. You can then delete the old default profile.
In a terminal:
firefox -profilemanager -no-remote
hit enter.
As a bonus you can also change the icon to the official Firefox icon.
In a terminal:
sudo sed '/Icon/ s/acs_//' -i /usr/share/applications/linpus-web.desktop
Finally reboot the AA1 to make the desktop aware of the new icon and browser location.
[Original Source]
http://macles.blogspot.com/2008/07/installing-firefox-3-on-acer-aspire-one.html
