Author Topic: Need old SSD + ZIF - AOA 110 ZG5 ZIF cable failed again  (Read 11602 times)
Offline mako6
  • Full Member
Re: Need old SSD + ZIF - AOA 110 ZG5 ZIF cable failed again
« Reply #15 on: July 20, 2013, 02:44:44 pm »
Anybody have any idea what these messages mean- what may be damaged? That UK ZIF cable may be wrong- the guy says it has a hard plastic connector on it, but ain't providing any photos.
« Last Edit: July 20, 2013, 02:50:48 pm by mako6 »
« Reply #16 on: July 20, 2013, 02:57:47 pm »
Try running:
sudo mv -v /etc/mtab /etc/mtab-old
sudo touch /etc/mtab
then reboot.
Do you still get the errors ?
Offline mako6
  • Full Member
« Reply #17 on: August 01, 2013, 03:29:14 am »
You are bearing in mind I am running it off the Live flash stick, since the SSD is still not connecting?
Offline mako6
  • Full Member
« Reply #18 on: August 01, 2013, 03:37:27 am »
mv: Cannot stat '/etc/mtab': Input/output error
touch: cannot touch SAME
« Reply #19 on: August 01, 2013, 11:56:57 am »
Have you considered doing a "proper" installation to the USB stick .. rather than a persistent "Live" session ?
Offline mako6
  • Full Member
« Reply #20 on: August 02, 2013, 02:12:11 am »
Well sure, if I knew what that was. BY definition, any system running off a stick or disc is a LIVE OS, ain't it? Actually I hate it cause it doesn't even have a Writer. The time to do that was when my healthy clean Pep3 was still accessible. But what does that have to do with not reading any USB, or SD card with these input/output errors. Thats not a stick problem, I think, it's damage I did to motherboard with the bleach (I think) or superglue. I'm about to make another big dissembly effort, but wish I could get a new ZIF cable for it.
« Reply #21 on: August 02, 2013, 03:14:26 am »
NO
A "Live" session is running from a non-writeable compressed image, and using a "persistence" file to write any changes .. the persistence file is then cleverly layered over the top of the non writeable image.
Effectively a LiveUSB is exact the same as a LiveCD, ie. NOTHING can be changed in the original image .. so it has to use some clever wizardry, dark magic, and a liberal sprinkling of pixie dust to be able to save changes.
A "proper" installation to a USB stick would be the same as a hard drive installation, ie. the whole file system is writeable.
Offline mako6
  • Full Member
« Reply #22 on: August 02, 2013, 05:00:01 pm »
So you need 2 sticks (pep3 + target) and functioning OS. BTW, just upgraded to latest 10.4 kernal 2.6-32-50. Think the old one had some serious vulnerabilities- had 2 cursor freeze crashes. Just looking to burn live CD to maybe install on lappy- Pep3 have later dist than 11-2012?
Anything special about doing install onto jump drive (besides getting confused and trashing your OS ;D). Any ideas about input/output (what section of motherboard would that be on). As it is now can't save files on anything removable- only way to transfer anything is save it online.
 So the saveable part is actually on the Peppermint3 folder on the LIVE stick, not on that other folder (which never allowed access)- made big one 700Mb-1gb. Stick must be under/equal to 2gb, and not HDSD, right, since just got a bunch of micro SD's.
Offline mako6
  • Full Member
« Reply #23 on: August 02, 2013, 05:19:44 pm »
Now it's Peppermint4 from 6-2013. Is that any bigger- I have brutal space limits (<7gig)
« Reply #24 on: August 02, 2013, 09:42:37 pm »
