Updates:
You can now choose from a number of pre-installed themes
LIBRE OFFICE - how big? Urgent
Started by mako6, July 10, 2013, 05:11:58 PM
Previous topic - Next topic
Mark Greaves (PCNetSpec)
OK,  let's get rid of OpenOffice too for now ..
Run:
sudo apt-get remove --purge openoffice.org*
then post the output from:
dpkg -l | grep openoffice
mako6
OK. Removed 2 things. No output from GREP
run:
sudo ppa-purge ppa:libreoffice/ppa
for APT in `find /etc/apt/ -name *.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
mako6
Will that purge all ppa's so I can't update opera or other things??
No .. it will only purge the libreoffice PPA that DOESSN'T contain a version for 10.04
mako6
when try to remove Libre PPA:
PPA to be removed: libreoffice ppa
Warning:  Could not find package list for PPA: libreoffice ppa
This is 2nd OUTPUT from infinite string:  Its still there.
ppa:transmissionbt/ppa
ppa:tualatrix/ppa
ppa:libreoffice/libreoffice-4-0
ppa:libreoffice/ppa
ppa:anonbeat/guayadeque
OK, fire up Synaptic
go to Settings>Repositories>Other Software (tab)
Find the line similar to
http://ppa.launchpad.net/libreoffice/ppa/ubuntu (http://ppa.launchpad.net/libreoffice/ppa/ubuntu) lucid main
and remove it
if present also remove
http://ppa.launchpad.net/libreoffice/ppa/ubuntu (http://ppa.launchpad.net/libreoffice/ppa/ubuntu) lucid (Source Code)
Close synaptic .. and post the output from
again
mako6
If I highlight it, will it only remove that one or ALL the depositories that are checked? Figure checked means installed so afraid to uncheck them
checked means ACTIVE
Yes it will only remove the one that's highlighted
mako6
OK done, no source.
OUTPUT:
ppa:tualatrix/ppa
OK, dya wanna try Libreoffice 4 again, or openoffice ?
mako6
Maybe you can give me all the instructions, and expected output, and I'll yell if I have any problems.
mako6
Did they change anything from 1 month ago? Yes they changed the depository I first used and apparently second isn't complete. Unless you know another.
Lets try Open Office.
OK, what happens if you run:
sudo apt-get install openoffice.org-writer
mako6
I have no repositories for it now, but I think I did before.
