Author Topic: LIBRE OFFICE - how big? Urgent  (Read 12602 times)
Re: LIBRE OFFICE - how big? Urgent
« Reply #45 on: August 16, 2013, 01:00:39 am »
Eh .. openoffice-writer should be in the default 10.04 repo
IS it in Synaptic ? .. if so install it .. not the whole openoffice, just writer
Offline mako6
  • Full Member
« Reply #46 on: August 16, 2013, 01:02:06 am »
This is what happened before we did all this cleaning:  Are we in a new world now?
---- Removed libre-writer. Tried installing openoffice.org-writer, got this:
Oh, gotta add that PPA- that gets purged too?
[email protected]:/home/mako4# apt-get install openoffice.org-writer
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies:
  openoffice.org-writer: Depends: openoffice.org-core (= 1:3.2.0-7ubuntu4.4) but it is not going to be installed
                         Depends: openoffice.org-base-core (= 1:3.2.0-7ubuntu4.4) but it is not going to be installed
                         Recommends: openoffice.org-emailmerge but it is not going to be installed
                         Recommends: openoffice.org-math but it is not going to be installed
E: Broken packages
« Reply #47 on: August 16, 2013, 01:06:52 am »
OK, run:
sudo apt-get install openoffice.org-core openoffice.org-base-core openoffice.org-emailmerge openoffice.org-math openoffice.org-writer
Any errors ?
[edit]
Theres' a PPA with LibreOffice 3.5.7 for 10.04 if you'd prefer to try that ?
« Last Edit: August 16, 2013, 01:08:32 am by Mark Greaves (PCNetSpec) »
Offline mako6
  • Full Member
« Reply #48 on: August 16, 2013, 01:08:31 am »
Checked Open Office writer and got same:
 unresolved dependencies (make sure needed repositories are added and enabled ):
 Depends: openoffice.org-core but it is not going to be installed
 Depends: openoffice.org-base-core but it is not going to be installed
« Reply #49 on: August 16, 2013, 01:08:55 am »
See above
Offline mako6
  • Full Member
« Reply #50 on: August 16, 2013, 01:14:48 am »
If it could install the OOo core, etc.. it would have, n'est pas? So it needs another repository for OOo. I think.
Sure whats the ppa for 3.6 Libre, though I looked at it and seemed to have a bunch of bugs, probably less than what I had since it MADE to work with 10.4
« Reply #51 on: August 16, 2013, 01:16:08 am »
Have you tried the command ?
Offline mako6
  • Full Member
« Reply #52 on: August 16, 2013, 01:17:25 am »
No, I'd rather try Libre 3.57
« Reply #53 on: August 16, 2013, 01:20:26 am »
OK, fire up synaptic, and remove the repositories for libreoffice-4
then send the output from:
for APT in `find /etc/apt/ -name *.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
Offline mako6
  • Full Member
« Reply #54 on: August 16, 2013, 01:28:33 am »
done
ppa:transmissionbt/ppa
ppa:tualatrix/ppa
ppa:anonbeat/guayadeque
« Reply #55 on: August 16, 2013, 01:30:57 am »
run:
sudo add-apt-repository ppa:libreoffice/libreoffice-3-5
sudo apt-get install libreoffice-writer
Offline mako6
  • Full Member
« Reply #56 on: August 16, 2013, 02:02:26 am »
DOne- haven't run it yet.
Got a few warnings. Are these crucial?:
/var/lib/dpkg/tmp.ci/preinst: 80: dpkg-maintscript-helper: not found
Selecting previously deselected package libreoffice-core.
Unpacking libreoffice-core (from .../libreoffice-core_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) ...
rmdir: failed to remove `/var/lib/libreoffice/basis3.4/program/': No such file or directory
rmdir: failed to remove `/var/lib/libreoffice/basis3.4': No such file or directory
Selecting previously deselected package libreoffice-base-core.
Unpacking libreoffice-base-core (from .../libreoffice-base-core_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) ...
Selecting previously deselected package python-uno.
Unpacking python-uno (from .../python-uno_1%3a3.5.7-0ubuntu4~lucid1_amd64.deb) ...
Offline mako6
  • Full Member
« Reply #57 on: August 16, 2013, 02:09:33 am »
Seems OK. Thanks very much. Is the program updatable from inside it?
 Is there a way to save the packages, so one doesn't have to download them again from places that don't have them? Like I could have done with the original or the OOo
« Reply #58 on: August 16, 2013, 02:23:09 am »
Not as far as I know no
Erm, yes, but you'd have to make sure you downloaded all the dependencies too (if any), and installing them may not be too easy
Theoretically you could clone the PPA, but my advice would be to switch to at least 12.04 or if you don't like Unity, Mint or Peppermint as soon as possible .. up to date software is going to get harder and harder to find for 10.04, and you're no longer receiving security updates.
Offline mako6
  • Full Member
« Reply #59 on: August 16, 2013, 02:31:57 am »
OK. Where are they- are they downloaded to one place? Figure if you just dump them back in that place, it will see them on subsequennt installation, not download them over, and also get any dependencies needed. Cause I want the space.
