Author Topic: installing JMRI  (Read 3006 times)
Offline donwatson
  • Getting older
installing JMRI
« on: August 15, 2013, 08:58:40 pm »
Hi All,
I would like to install the JMRI suite of programs for the garden railway layout.
Can anyone help me. I have a folder in Downloads called JMRI.3.4-r23744.tgz but that is as far as I dare to go.
I would like the tutorials etc. but will see what happens when/if I get this running.
Thanks for looking..
take care
Don W
Novatech build
External 2TiB HD
Emegra
  • Guest
Re: installing JMRI
« Reply #1 on: August 15, 2013, 09:03:08 pm »
It would have to be compiled to run on your system (something I know little about) but if you right click on the file and extract it there is sometimes a README with instructions for installations, might be worth having a look
Good luck
Re: installing JMRI
« Reply #2 on: August 15, 2013, 09:21:03 pm »
It's a java app so doesn't need compiling .. right click on that JMRI.3.4-r23744.tgz file and select "Extract Here" .. you'll then find a folder called JMRI, enter it .. now click on the application called DecoderPro .. the application should start.
Offline donwatson
  • Getting older
Re: installing JMRI
« Reply #3 on: August 16, 2013, 12:11:04 am »
Thanks Guys.
Mark, it opened with an error message but it seems to run ok.
I will download the the Panel Layout tutorial and the Decoder tutorial and see what happens.
Thanks again
take care
Don W
Novatech build
External 2TiB HD
Re: installing JMRI
« Reply #4 on: August 16, 2013, 12:24:26 am »
it may be that you have the opensource version of JAVA instead of the Oracle version
If you have problems, we'll look into that.
Offline donwatson
  • Getting older
Re: installing JMRI
« Reply #5 on: August 16, 2013, 10:58:57 am »
I downloaded the tutorials and had a look inside the JMRI folder.
There are various executable files within this folder and I chose Panel Pro as I am doing the Panel tutorial.
When the programme opened it came up with the JMRI Help box and the Panel Pro box.
I can expan/contract and minimise these boxes but I can't close them or Quit.
I ran the InstallTest exe file and it confirmed I am running Java 1.6.
I am now stuck, should I have ran these in a terminal window ?
I will post this and shut down the computer while i check out the windross mail>
take care
don w
Novatech build
External 2TiB HD
Re: installing JMRI
« Reply #6 on: August 16, 2013, 11:53:02 am »
OK, so you're on java 1.6 .. still probably the open sourced version and not the sun/oracle version ;)
What's the output from:
update-alternatives --display java
Offline donwatson
  • Getting older
Re: installing JMRI
« Reply #7 on: August 16, 2013, 12:53:34 pm »
Hi Mark
java - auto mode
  link currently points to /usr/lib/jvm/java-6-openjdk-i386/jre/bin/java
/usr/lib/jvm/java-6-openjdk-i386/jre/bin/java - priority 1061
  slave java.1.gz: /usr/lib/jvm/java-6-openjdk-i386/jre/man/man1/java.1.gz
Current 'best' version is '/usr/lib/jvm/java-6-openjdk-i386/jre/bin/java'.
Sorry about this Mark but all seems to be well again.
I have run Decoder Pro and set Preferences, then I ran Panel Pro and confirmed Preferences and everything seems to be ok.
take care
Don W
PS Thanks for the help, I will ( probably ) be back
« Last Edit: August 16, 2013, 01:29:00 pm by donwatson »
Novatech build
External 2TiB HD
Re: installing JMRI
« Reply #8 on: August 16, 2013, 02:16:12 pm »
If you decide you want to try Oracle Java 8 (bearing in mind the security issues)
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get install oracle-java8-installer
sudo apt-get install oracle-java8-set-default
Then post the output from:
java -version
javac -version
Also go here:
http://www.java.com/en/download/testjava.jsp
and check it says you're running Java SE 8
I have no idea how to test if JMRI works .. but I just tested it with Oracle Java 8 and all the menu items *seem* to work.
That said, if it's working in the open source java .. stick with that, it's more secure.
Offline donwatson
  • Getting older
Re: installing JMRI
« Reply #9 on: August 16, 2013, 04:22:52 pm »
I have been running the Panel Pro this afternoon and have just completed the first tutorial.
Everything is ok at the moment.
I did read your message and tried to test java but it said I needed to install a plugin, so I have left it alone for the moment.
Thanks again for your help.
take care
Don W
Novatech build
External 2TiB HD
