Author Topic: Peppermint 3  (Read 6997 times)
Offline Melissa
  • Vintage geek
  • Gender: Female
Peppermint 3
« on: August 19, 2013, 01:01:41 pm »
Mark, I will be ready about 2 pm- just have to wash my hair and have some brunch. Got up quite late- had terminal commands going round in my dreams LOL- bit tired so got up rather late.
P.S- the Star Trek HD works on the laptop on m player! Even the Enterprise ones which smudge on this netbook.
See ya later.
My computer: Asus notebook x102B, running on Peppermint 9.
Re: Peppermint 3
« Reply #1 on: August 19, 2013, 01:06:20 pm »
Okey dokey :)
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #2 on: August 19, 2013, 02:07:15 pm »
Just have to wash my plate and will be there in a mo...
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #3 on: August 19, 2013, 02:20:12 pm »
Hello, got laptop on.
Re: Peppermint 3
« Reply #4 on: August 19, 2013, 02:32:25 pm »
Enabling the extra software repositories
In the menu, go to System Tools > Synaptic Package Manager, enter your password, when Synaptic starts -
Go to Settings > Repositories .. when a new window opens -
On the "Peppermint Software" tab, make sure ALL 4 boxes are ticked.
On the "Other Software" tab, make sure all boxes are ticked EXCEPT the cdrom:[Peppermint 3_Three_ - Release i386 (some-date-or-other)]/ precise
Click Close
Click the Reload button on the Synaptic toolbar.
Close Synaptic.
(It's IMPORTANT that you close Synaptic, or the commands in the next stage won't run)
Tell me when you're done, or if you have any problems.
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #5 on: August 19, 2013, 02:43:12 pm »
Yes, all done thanks. Sorry took so long, had to create a new PW for this forum as forgot what it was- needed to log in on the laptop as well as the netbook.
Re: Peppermint 3
« Reply #6 on: August 19, 2013, 02:56:22 pm »
OK .. make SURE Synaptic is closed, then open a terminal (Ctrl+Alt+T) and run the following commands
Best to copy/paste commands into the terminal from now on:
sudo apt-get upgrade
sudo apt-get dist-upgrade
Tell me when you've run those 3 commands .. or any errors
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #7 on: August 19, 2013, 03:04:47 pm »
Ok, think this is ok so far except asking about the disk space:
78 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
Need to get 175 MB of archives.
After this operation, 43.2 MB of additional disk space will be used.
Do you want to continue [Y/n]?
Re: Peppermint 3
« Reply #8 on: August 19, 2013, 03:19:54 pm »
hit y (and then enter)
thats not large ;)
Tell me when done
« Last Edit: August 19, 2013, 03:25:47 pm by Mark Greaves (PCNetSpec) »
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #9 on: August 19, 2013, 03:30:20 pm »
It is running along...will let you know when it's done.
Re: Peppermint 3
« Reply #10 on: August 19, 2013, 03:33:35 pm »
OK
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #11 on: August 19, 2013, 03:45:59 pm »
Well it was..until the battery suddenly died!!! And must be a Firefox thing because when the netbook battery dies without me seeing it and I plug it in all the pages I had up are still there. Also the netbook has a warning box to tell me to plug in the charger but this one doesn't.
Got this in the terminal:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Re: Peppermint 3
« Reply #12 on: August 19, 2013, 03:49:19 pm »
Make sure you're connected by power lead for now and run:
Tell me when done, or any errors
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #13 on: August 19, 2013, 04:00:37 pm »
It is happily unpacking Mark! Phew will have to get this laptop a cooling mat- it is getting rather warm...
EDIT-it's done.
Re: Peppermint 3
« Reply #14 on: August 19, 2013, 04:05:44 pm »
OK, as it will have installed a newer kernel, REBOOT (to load the new kernel).
Once rebooted, tell me what software you want on top of this lot
VLC
Firefox
LibreOffice
eg. do you want
GIMP (Linux Photoshop alternative)
or anything else ?
