Author Topic: Peppermint 3  (Read 6994 times)
Re: Peppermint 3
« Reply #30 on: August 19, 2013, 05:33:11 pm »
Hahaha :)
As a Scot, I'm guessing you also have the chicken wire underpants ?
To protect you (when wearing a kilt) from the wild vicious lesser spotted highland haggis's ?
« Last Edit: August 19, 2013, 05:37:01 pm by Mark Greaves (PCNetSpec) »
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #31 on: August 19, 2013, 05:37:15 pm »
I do have a 1920s/ early 1930s wind up gramophone!
I had one of them I got rid of it scratched hell out all my CD's :)
 :P
Ok it wants its next command.
My computer: Asus notebook x102B, running on Peppermint 9.
Emegra
  • Guest
Re: Peppermint 3
« Reply #32 on: August 19, 2013, 05:37:25 pm »
No NO NO a true Scotsman doesn't wear underpants :)
Re: Peppermint 3
« Reply #33 on: August 19, 2013, 05:39:03 pm »
What, even with those wild haggis's' around ?
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #34 on: August 19, 2013, 05:40:06 pm »
Well saves on laundry I suppose!
Re: Peppermint 3
« Reply #35 on: August 19, 2013, 05:42:08 pm »
Ahh, suddenly makes sense .. so you can s**t yourself cleanly when being chased by a vicious highland haggis
Erm .. sorry Scots .. I don't really want a beating ;)
Emegra
  • Guest
Re: Peppermint 3
« Reply #36 on: August 19, 2013, 05:43:30 pm »
were no scared o a wee nip fae a haggis :)
Re: Peppermint 3
« Reply #37 on: August 19, 2013, 05:49:28 pm »
Quote from: Emegra
Ahh, so "haggis" is now the new colloquialism for Whiskey/Tennents Super/other heavily inebriating liquid ?
Says the man you sent a bottle of JD to ;)
« Last Edit: August 19, 2013, 06:02:54 pm by Mark Greaves (PCNetSpec) »
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #38 on: August 19, 2013, 05:51:10 pm »
Laptop wants its next command when you two are done with haggis, undies and whisky. :P
Re: Peppermint 3
« Reply #39 on: August 19, 2013, 05:54:06 pm »
OK, run:
sudo apt-get install ubuntu-restricted-extras lubuntu-restricted-extras libdvdread4 pulseaudio pulseaudio-utils pavucontrol
tell me when done, or any errors
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #40 on: August 19, 2013, 06:05:11 pm »
It is done.
Re: Peppermint 3
« Reply #41 on: August 19, 2013, 06:06:33 pm »
run:
sudo /usr/share/doc/libdvdread4/install-css.sh
Offline Melissa
  • Vintage geek
  • Gender: Female
Re: Peppermint 3
« Reply #42 on: August 19, 2013, 06:12:57 pm »
It's done.
Re: Peppermint 3
« Reply #43 on: August 19, 2013, 06:13:15 pm »
Installing the Jupiter power management application
This is an optional install, but I recommend it for laptops, as when you switch from mains power to battery power, the Jupiter panel applet will switch your CPU into power saving mode, which will make your battery last longer.
Open a terminal and run
sudo add-apt-repository ppa:webupd8team/jupiter
sudo apt-get install jupiter
Now REBOOT (to load the application) .. you'll then see a new icon by the clock that looks like a lightening bolt .. when you unplug the mains power, this icon should change to reflect it has set the CPU to "Power Saving" mode, when you plug it back in, it should switch to "Maximum Performance" mode.
You can also switch modes manually by clicking the lightning bolt icon, and selecting the "Performance" mode.
Be aware .. with certain laptops, the switching to "Power Saving" isn't 100% accurate .. so when you unplug your laptop from the mains to run on battery for an extended period, visually check the icon has changed to "Power Saving" mode, if it hasn't, do it manually .. and if necessary switch it back to "Performance" when the laptop is plugged in.
Offline Degsy
  • Sr. Member
Re: Peppermint 3
« Reply #44 on: August 19, 2013, 06:21:52 pm »
Would the. Command for the Jupiter thing be the same for Peppermint 4? Might as well use that for my lappy.
