Author Topic: tlp  (Read 1260 times)
Offline Degsy
  • Sr. Member
tlp
« on: August 19, 2013, 09:33:52 pm »
as suggested new thread for tlp. I would be obliged if you could guide me through this installation as I have only ever done installs through the software centre.
Many thanks,
Degsy
Offline Degsy
  • Sr. Member
Re: tlp
« Reply #1 on: August 19, 2013, 09:51:30 pm »
Actually Mark, managed to follow the instructions on the link you gave me and it seems to be working ok, will come back to you if I find any problems. Any comments etc that you think might be helpful will, of course, be gratefully received.
Cheers,
Degsy
Re: tlp
« Reply #2 on: August 19, 2013, 10:03:46 pm »
Yup nothing hard about installing TLP in peppermint 4 .. just a few commands
sudo add-apt-repository ppa:linrunner/tlp
sudo apt-get install tlp tlp-rdw smartmontools ethtool
then start it wth:
sudo tlp start
and check it's running with:
sudo tlp-stat
As long as (after a reboot) that last command returns
TLP power save = enabled
as part of the output, you're good to go .. your CPU should automagically get throttled back when not under load.
References:
http://www.noobslab.com/2013/07/how-to-improve-laptop-power-management.html
and/or here:
http://linrunner.de/en/tlp/docs/tlp-linux-advanced-power-management.html
« Last Edit: August 19, 2013, 10:05:39 pm by Mark Greaves (PCNetSpec) »
Offline Degsy
  • Sr. Member
Re: tlp
« Reply #3 on: August 19, 2013, 10:11:59 pm »
Yes, have rebooted and all working well. I am amazed at the difference in battery life since going to peppermint 4 from XP, I could hardly get a boot up using battery power under XP but now it lasts whilst using Pep 4. Really pleased with this and haven't booted XP since it was installed.
Degsy
Re: tlp
« Reply #4 on: August 19, 2013, 10:24:47 pm »
Pleased to hear it :)
