Author Topic: Error formatting USB stick. (Solved)  (Read 60318 times)
Offline Toonman
« on: August 25, 2013, 03:16:19 pm »
I am having difficulty formatting my Lexar 16gb usb stick.   I get 'Error formatting disk'. Error synchronizing after initial wipe: Timed out waiting for object (udisks-error-quark, 0)
Also I cannot un mount it.
Any ideas?
« Last Edit: August 26, 2013, 07:49:25 am by Toonman »
Re: Error formatting USB stick.
« Reply #1 on: August 25, 2013, 04:43:15 pm »
Read this:
http://itsfoss.com/how-to-format-a-sd-card-or-usb-drive-in-ubuntu-12-10/
Then install gparted:
sudo apt-get install gparted
and use that to format the USB stick
Unmount it from the command line with:
sudo umount -f /dev/sdbX
where bX is the drive/partition number.
Or just don't mount it in the first place ;)
Offline Toonman
« Reply #2 on: August 26, 2013, 07:49:09 am »
Thanks Mark. I completely forgot about Gparted.  :-[
Works now.  :)
Re: Error formatting USB stick. (Solved)
« Reply #3 on: August 26, 2013, 02:20:28 pm »
You're welcome :)
Offline LJ_Dude
« Reply #4 on: July 01, 2018, 03:59:01 am »
I have a hard drive I am trying to use for my Ubuntu PC, and I got the same response when trying to format it. Specifically, there is one partition that does not erase itself. I looked at it in GParted, but it does not show that there are any partitions on the disk. It shows an exclamation point within a large red dot, and when I right-click "unallocated" and click information, it tells me: /dev/sdb: unrecognized disk label
I have no idea what that means. Can I get some help?
Offline LJ_Dude
« Reply #5 on: July 05, 2018, 10:00:49 pm »
Nevermind, I fixed the disk. I asked a friend to help and they added a partition in GParted and it cleared up. Wierd, but it's fine. (For the most part.)
