Author Topic: Firefox is not always the default browser [SOLVED]  (Read 3911 times)
« on: September 08, 2013, 01:48:45 pm »
I am running Peppermint 3 on a Dell D505 laptop because it doesn't support PAE and hence Ubuntu 12.04.
I like many aspects of Peppermint but don't like the cloud behaviour and have installed all my favourite applications such as Firefox, which I have set as the default browser.
However, links in some applications open Chromium.  Although this is irritating, I could live with it (just) except that on occasion Chromium fails to display a perfectly good HTML file.  I have just installed the Audacity help manual (It doesn't go where it's supposed to, by the way) but clicking on the help menu item in Audacity brings up Chromium which fails to display the file.
When entering the file address (file:///usr/share/audacity/help/manual/index.html) into Firefox it displays correctly.
I would be grateful for advice on persuading Peppermint to regard Firefox as the default browser in all situations.
Thank you.
« Last Edit: September 08, 2013, 02:50:26 pm by Keith »
Re: Firefox is not always the default browser
« Reply #1 on: September 08, 2013, 01:56:36 pm »
what's the output from:
update-alternatives --display x-www-browser
update-alternatives --display gnome-www-browser
« Last Edit: September 08, 2013, 01:59:00 pm by Mark Greaves (PCNetSpec) »
« Reply #2 on: September 08, 2013, 02:34:21 pm »
keith@D505 ~ $ update-alternatives --display x-www-browser
x-www-browser - auto mode
  link currently points to /usr/bin/chromium-browser
/usr/bin/chromium-browser - priority 40
/usr/bin/firefox - priority 40
Current 'best' version is '/usr/bin/chromium-browser'.
keith@D505 ~ $ update-alternatives --display gnome-www-browser
gnome-www-browser - auto mode
Ah, that says it all, doesn't it?  Now to set the priorities?
« Reply #3 on: September 08, 2013, 02:45:13 pm »
OK, let's do this the GUI way ..
Install galternatives:
sudo apt-get install galternatives
Now go to
menu > System Tools > Alternatives Configurator
in the left-hand pane, select gnome-www-browser
in the right-hand pane, put the dot next to 40  /usr/bin/firefox
in the left-hand pane, select x-www-browser
Close the Alternatives Configurator tool
Check links now open Firefox instead of chrome.
« Reply #4 on: September 08, 2013, 02:49:42 pm »
Mark, you're a star.  But I've said that before!
Many thanks.
Re: Firefox is not always the default browser [SOLVED]
« Reply #5 on: September 08, 2013, 03:02:28 pm »
:) . I take it, it worked then ?
« Reply #6 on: September 08, 2013, 03:04:43 pm »
Absolutely.  I am a happy bunny.
Firefox rules OK.
Tell me - what's it like to know what you're doing?  It's not something that I've ever experienced.
« Reply #7 on: September 08, 2013, 04:03:53 pm »
Who said I know what I'm doing .. didn't you notice I had to ask if it worked ;)
