Author Topic: Ralink Wireless USB adapter Linux Mint 15  (Read 77561 times)
Offline fastconnection
« on: September 22, 2013, 01:26:00 am »
Hey folks  New Linux convert here!
Postby connectionfast on Sat Sep 21, 2013 5:27 pm
Hi folks!
I have a Ralink Wifi adapter usb dongle and surprise...it doesnt seem to work with Mint 15. Please enlighten me in the simplest terms possible please! Its an RALINK RT 2860.
much appreciated!
PS The device is found after entering an "inxi -n" but thats as far as ive got:
pete@pete-ESPRIMO-P ~ $ inxi -n
Network: Card: Realtek RTL-8139/8139C/8139C+ driver: 8139too
IF: eth0 state: unknown speed: 100 Mbps duplex: full mac: 00:30:05:e3:76:b4
Card-2: Ralink RT2870/RT3070 Wireless Adapter
IF: N/A state: N/A mac: N/A
« Last Edit: September 22, 2013, 08:38:04 pm by fastconnection »
Re: Ralink Wireless USB adapter Linux Mint 15
« Reply #1 on: September 22, 2013, 01:38:24 am »
Hi fastconnection, and welcome to the forum :)
can you post the output from:
lsusb
sudo lshw -C network
« Reply #2 on: September 22, 2013, 10:29:21 am »
Hi there and thanks for the nice welcome!
Heres the info!:
lsusb
Bus 002 Device 002: ID 192f:0916 Avago Technologies, Pte.
Bus 003 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 001 Device 004: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
and:
  *-network
       product: RTL-8139/8139C/8139C+
       physical id: 4
       bus info: pci@0000:0c:04.0
       logical name: eth0
       version: 10
       serial: 00:30:05:e3:76:b4
       capacity: 100Mbit/s
       width: 32 bits
       capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full ip=192.168.1.64 latency=64 link=yes maxlatency=64 mingnt=32 multicast=yes port=MII speed=100Mbit/s
       resources: irq:23 ioport:a000(size=256) memory:d0100000-d01000ff
« Reply #3 on: September 22, 2013, 12:50:03 pm »
Can you unplug the USB wireless adapter, wait 10 seconds, replug it, then send the output from:
dmesg | tail -n 40
lsmod | grep rt2
Please ignore this link for now:
https://dl.dropboxusercontent.com/u/11876059/DPO_RT5572_LinuxSTA_2.6.1.3_20121022.tar.gz
it's a reminder for me in case we need to use it later.
« Last Edit: September 22, 2013, 02:02:35 pm by Mark Greaves (PCNetSpec) »
« Reply #4 on: September 22, 2013, 02:05:52 pm »
ok many thanks heres the result:
 dmesg | tail -n 40
[   17.368723] udevd[415]: starting version 175
[   17.593354] lp: driver loaded but no devices found
[   17.616218] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   17.617411] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0x8410, revision 0
[   17.617527] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0x8050
[   17.634544] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver v0.05
[   17.634733] sp5100_tco: PCI Revision ID: 0x13
[   17.634764] sp5100_tco: failed to find MMIO address, giving up.
[   17.766342] microcode: CPU0 sig=0xf47, pf=0x10, revision=0x3
[   17.800180] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input5
[   17.800413] input: HDA ATI SB Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input6
[   17.800610] input: HDA ATI SB Line Out as /devices/pci0000:00/0000:00:14.2/sound/card0/input7
[   17.964201] device-mapper: multipath: version 1.5.1 loaded
[   18.186881] microcode: CPU1 sig=0xf47, pf=0x10, revision=0x3
[   18.195939] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   19.697679] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   20.124961] init: failsafe main process (742) killed by TERM signal
[   20.513932] Bluetooth: Core ver 2.16
[   20.513976] NET: Registered protocol family 31
[   20.513980] Bluetooth: HCI device and connection manager initialized
[   20.513995] Bluetooth: HCI socket layer initialized
[   20.514000] Bluetooth: L2CAP socket layer initialized
[   20.514012] Bluetooth: SCO socket layer initialized
[   20.526009] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.526016] Bluetooth: BNEP filters: protocol multicast
[   20.526032] Bluetooth: BNEP socket layer initialized
[   20.529158] Bluetooth: RFCOMM TTY layer initialized
[   20.529180] Bluetooth: RFCOMM socket layer initialized
[   20.529183] Bluetooth: RFCOMM ver 1.11
[   20.993974] ppdev: user-space parallel port driver
[   21.026780] init: avahi-cups-reload main process (856) terminated with status 1
[   23.193508] 8139too 0000:0c:04.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   27.673515] init: plymouth-upstart-bridge main process (808) killed by TERM signal
[  202.095824] usb 1-10: USB disconnect, device number 4
[  228.780054] usb 1-10: new high-speed USB device number 5 using ehci-pci
[  228.929520] usb 1-10: New USB device found, idVendor=148f, idProduct=3070
[  228.929527] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  228.929533] usb 1-10: Product: 802.11 n WLAN
[  228.929537] usb 1-10: Manufacturer: Ralink
[  228.929541] usb 1-10: SerialNumber: 1.0
« Reply #5 on: September 22, 2013, 02:07:57 pm »
What's the output from:
lsmod | grep rt2
modinfo rt2800usb | grep 3070
rfkill list
« Last Edit: September 22, 2013, 02:16:41 pm by Mark Greaves (PCNetSpec) »
« Reply #6 on: September 22, 2013, 02:12:47 pm »
lsmod | grep rt2  : doesnt generate anything - just prompt
alias:          usb:v148Fp3070d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v8516p3070d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07B8p3070d*dc*dsc*dp*ic*isc*ip*in*
« Reply #7 on: September 22, 2013, 02:14:16 pm »
Odd.
OK, what happens if you run:
sudo modprobe rt2800usb
does wireless spring to life ?
« Reply #8 on: September 22, 2013, 02:19:27 pm »
what would i expect to see if it does? (shows you just how NEW I am!  ;D
« Reply #9 on: September 22, 2013, 02:21:37 pm »
What happens if you normal (left) click the networkmanager icon (by the clock), is your network listed ?
or what's the output from:
iwconfig
« Reply #10 on: September 22, 2013, 02:24:29 pm »
iwconfig
Thanks for your time by the way - determined to persevere - Linux is superb - wish I had used it years ago
« Reply #11 on: September 22, 2013, 02:27:51 pm »
OK that didn't work then :(
odd because rt2800usb has the right ID string  :o
Right we're going to compile the drivers from Ralink .. so whilst I type up the intructions, can you install linux-headers-generic and build-essential with this command:
« Reply #12 on: September 22, 2013, 02:30:26 pm »
Reading package lists... Done
Building dependency tree
Package build-essential is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'build-essential' has no installation candidate
« Reply #13 on: September 22, 2013, 02:43:41 pm »
Eh .. how can build-essential be missing ?
Are you sure this is Mint 15 .. and not something like Backtrack ?
run:
sudo apt-get install build-essential
« Reply #14 on: September 22, 2013, 02:54:01 pm »
yep definitely mint 15.
on the update i get this?
E: Type ‘http://ftp.us.debian.org/debian’ is not known on line 1 in source list /etc/apt/sources.list.d/additional-repositories.list
E: The list of sources could not be read.
