Author Topic: Peppermint os 4 wifi not working.  (Read 16608 times)
Offline peppernoob
« on: October 13, 2013, 05:28:13 pm »
Hi everyone and today I decided to install peppermint os on my old netbook (dell inspiron mini 10) since windows xp was being slow. All was well except that my wifi was not working. So according to marks instructions on an old thread http://linuxforums.org.uk/index.php?topic=9939.0 I decided to try sudo lshw -C network on terminal. Here are the results   *-network
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 02
       serial: 00:24:e8:94:37:32
       capacity: 100Mbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.1.17 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:40 ioport:2000(size=256) memory:d8410000-d8410fff memory:d8400000-d840ffff memory:d8420000-d843ffff
  *-network
       product: BCM4312 802.11b/g LP-PHY
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 01
       width: 64 bits
       configuration: driver=b43-pci-bridge latency=0
       resources: irq:17 memory:d8000000-d8003fff
If anyone has a solution to this issue I would really appreciate it. Thank you for your time and have a wonderful day.
Re: Peppermint os 4 wifi not working.
« Reply #1 on: October 13, 2013, 05:34:11 pm »
IGNORE THIS POSTING .. SEE MY NEXT ONE
Connect to your router with an ethernet cable.
Open a terminal (Ctr;+Alt+T), and run:
sudo apt-get install b43 firmware-b43-installer
sudo modprobe b43
did your wireless spring to life ?
« Last Edit: October 13, 2013, 05:47:18 pm by Mark Greaves (PCNetSpec) »
Offline peppernoob
« Reply #2 on: October 13, 2013, 05:39:36 pm »
No When I input-ed the first option I got E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
« Reply #3 on: October 13, 2013, 05:44:44 pm »
Ignore the above anyway .. just spotted the LP-PHY
First make sure the Software Manager, Synaptic package manager, and the Software Updater are all CLOSED .. and that you're connected to your router with an ethernet cable.
THEN open a terminal and run:
sudo modprobe -r b43
sudo apt-get install b43 firmware-b43-lpphy-installer
sudo modprobe b43
« Last Edit: October 13, 2013, 05:49:01 pm by Mark Greaves (PCNetSpec) »
Offline peppernoob
« Reply #4 on: October 13, 2013, 05:48:45 pm »
No this time I got  sudo modprobe -r b43
[sudo] password for
Reading package lists... Done
Building dependency tree
E: Unable to locate package b43
E: Unable to locate package firmware-b43-lpphy-installer
mamu@mamu-Inspiron-1010 ~ $ sudo modprobe b43
« Reply #5 on: October 13, 2013, 05:50:02 pm »
Are you connected to your router with an ethernet cable ?
Offline peppernoob
« Reply #6 on: October 13, 2013, 05:51:35 pm »
Yes I am typing to you from chromium on the same laptop.
« Reply #7 on: October 13, 2013, 05:52:51 pm »
Run:
then try those commands again.
Offline peppernoob
« Reply #8 on: October 13, 2013, 05:57:09 pm »
No I got sudo modprobe -r b43
 ~ $ sudo apt-get install b43 firmware-b43-lpphy-installer
« Reply #9 on: October 13, 2013, 06:01:38 pm »
if you fire up the Synpatic package manager .. then go to settings > repositories > peppermint software (tab)
are the 4 top boxes ticked ?
« Reply #10 on: October 13, 2013, 06:04:14 pm »
back in 7 mins
Offline peppernoob
« Reply #11 on: October 13, 2013, 06:08:30 pm »
Yes they are ticked.
« Reply #12 on: October 13, 2013, 06:12:26 pm »
what's the contents of
gedit /etc/apt/sources.list
and is this a hard drive install of Peppermint 4, or a liveCD ?
« Reply #13 on: October 13, 2013, 06:15:29 pm »
Sorry, my mistake ..
sudo apt-get install b43-fwcutter firmware-b43-lpphy-installer
sudo modprobe b43
« Last Edit: October 13, 2013, 06:17:02 pm by Mark Greaves (PCNetSpec) »
Offline peppernoob
« Reply #14 on: October 13, 2013, 06:16:09 pm »
I already installed peppermint to hardrive using an usb. The sources list says #deb cdrom:[Peppermint 4 _Four_ - Release i386 (20130502)]/ raring main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ca.archive.ubuntu.com/ubuntu/ raring main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates main restricted
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring universe
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates universe
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring multiverse
deb http://ca.archive.ubuntu.com/ubuntu/ raring-updates multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ca.archive.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb-src http://ca.archive.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu raring-security main restricted
deb-src http://security.ubuntu.com/ubuntu raring-security main restricted
deb http://security.ubuntu.com/ubuntu raring-security universe
deb-src http://security.ubuntu.com/ubuntu raring-security universe
deb http://security.ubuntu.com/ubuntu raring-security multiverse
deb-src http://security.ubuntu.com/ubuntu raring-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu raring partner
# deb-src http://archive.canonical.com/ubuntu raring partner
## Uncomment the following two lines to add software from Ubuntu's
## 'extras' repository.
## This software is not part of Ubuntu, but is offered by third-party
## developers who want to ship their latest software.
# deb http://extras.ubuntu.com/ubuntu raring main
# deb-src http://extras.ubuntu.com/ubuntu raring main
