Author Topic: Getting lost with Linux and Stdin in audio terms. Trying to use rsound.  (Read 5894 times)
Offline AdrianH
Re: Getting lost with Linux and Stdin in audio terms. Trying to use rsound.
« Reply #15 on: October 15, 2013, 11:14:25 pm »
Found a way to do it, in fact two methods after more searching of the Internet
192.168.1.69~> arecord -D plughw:0,0 -f S16_LE | ssh -C [email protected] aplay -f S16_LE
This asks for the password to access 192.168.1.65 as it works over SSH.  It uses the alsa utilities arecord and aplay
The second method that appears to work, although why I do not know yet
192.168.1.69~> arecord -D plughw:0,0 -f S16_LE | rsdplay -s 192.168.1.65
the above requires rsd running on the remote computer but does not ask for any password.
I am not sure why it works yet as I have not defined the stream as raw pcm, but I am wondering if the arecord is doing this for me?
Cheers
Adrian
Thought I would add a little bit more information to this, as a record for me and if anyone finds it interesting.
The first method using ssh has a typical network data output of 11.4 KiB/s and a typical delay of 3.5 seconds ober my own internal network.
the second method using rsdplay takes the network output to 17 KiB/s but the delay drops to less than 1 second
« Last Edit: October 16, 2013, 12:16:03 am by AdrianH »
« Reply #16 on: October 16, 2013, 02:30:35 am »
Thanks for taking the time to post your solution, I'm sure it'll come in handy for someone :)
