Author Topic: (SOLVED) Flashplugin-installer  (Read 7091 times)
Offline Toonman
« on: October 29, 2013, 07:52:21 am »
Re installed Mint 4 recently.  I keep getting this message.
Failure to download extra data files
The following packages requested additional data downloads after package installation, but the data could not be downloaded or could not be processed.
flashplugin-installer
The download will be attempted again later, or you can try the download again now.  Running this command requires an active Internet connection.
If run the command:
flashplugin-installer: downloading http://archive.canonical.com/pool/partner/a/adobe-flashplugin/adobe-flashplugin_11.2.202.310.orig.tar.gz
it just sits there doing nothing.  When I re boot the same notice comes up again.
Any thoughts?
« Last Edit: October 30, 2013, 06:18:19 pm by Toonman »
Re: Flashplugin-installer
« Reply #1 on: October 29, 2013, 01:59:01 pm »
First thing to try -
sudo apt-get remove --purge flashplugin-installer
sudo apt-get install flashplugin-installer
Offline Toonman
(SOLVED) Re: Flashplugin-installer
« Reply #2 on: October 30, 2013, 03:54:44 pm »
That seems to have done it. Thanks
« Last Edit: October 30, 2013, 06:17:40 pm by Toonman »
Re: (SOLVED) Flashplugin-installer
« Reply #3 on: October 30, 2013, 06:24:48 pm »
Всегда пожалуйста :)
