Author Topic: <ALT> F2 search in Kubuntu  (Read 1699 times)
Offline pooky2483
« on: November 17, 2013, 04:03:22 pm »
I am having trouble seeing the search result when I press <ALT> + F2, it shows the results on a black background with black text! How can I fix this, where do I go to change the colours?
Re: <ALT> F2 search in Kubuntu
« Reply #1 on: November 17, 2013, 06:43:09 pm »
I can't personally help there (haven't used KDE for ages) .. but that's quite funny, are those the default colours ?
Maybe this will help ?:
http://www.bbc.co.uk/accessibility/guides/change_colours/computer/linux/kde/
« Last Edit: November 17, 2013, 06:46:09 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: November 17, 2013, 07:17:33 pm »
Nope, checked out the website and followed the instructions and went through every scheme I had and even changed colours but its still black text on a black background!!!
