Author Topic: Choppy juddery video Zorin 7.1  (Read 24793 times)
Re: Choppy juddery video Zorin 7.1
« Reply #60 on: December 10, 2013, 01:00:28 pm »
Somewhere in your menu's you should find an application called "Ubntu AMD Catalyst Installer" .. have you found that and run it yet ?
Offline skronk
« Reply #61 on: December 10, 2013, 01:35:53 pm »
This was not on the menu until this morning. However when I access it and press OK nothing happens !
Offline skronk
« Reply #62 on: December 10, 2013, 02:05:47 pm »
Don't know if this helps on system settings
Offline skronk
« Reply #63 on: December 10, 2013, 02:19:45 pm »
« Reply #64 on: December 10, 2013, 02:41:55 pm »
Before trying that .. is theree an option in your current Catalyst Control Centre to turn on "Hardware Accelerated video decoding" or similar ?
Have you set VLC to use hardware acceleration ?
Offline skronk
« Reply #65 on: December 10, 2013, 03:11:17 pm »
Hi,
No option in Catalyst Control Centre.
Accelarated GPU in VLC selected already..
However symptoms are the same using SMplayer, built in media player and VLC !!
When using Openshot symptoms become increased.
« Reply #66 on: December 10, 2013, 04:08:46 pm »
I have a feeling we've tried this before, but what happens if you run:
sudo aticonfig --initial -f
Offline skronk
« Reply #67 on: December 10, 2013, 05:02:45 pm »
No supported adapters detected.
« Reply #68 on: December 10, 2013, 07:03:58 pm »
OK, seems your APU isn't supported in the 13.4 drivers .. but it is in >= 13.6 (beta) drivers.
So let's install the 13.11 beta drivers from ATI.....
Enter commands below EXACTLY as typed .. capital letters where used ;)
Open a terminal and run:
sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases ia32-libs-multiarch lib32gcc1
(to install some build/dependencies)
Now run
mkdir ~/Desktop/catalyst13.11-temporary
then download this file:
http://www2.ati.com/drivers/beta/amd-catalyst-13.11-beta-v9.4-linux-x86.x86_64.run.zip
and put it in the catalyst13.11-temporary diectory that's now on your desktop.
Now back in a the terminal run:
cd ~/Desktop/catalyst13.11-temporary
unzip amd-catalyst-13.11-beta-v9.4-linux-x86.x86_64.run.zip
sudo sh *.run --buildpkg Ubuntu/raring
Hopefully that will have built the installation packages.
DO NOT install them yet (there's some stuff left to do first) .. after completing the above, just post the output from:
ls -a ~/Desktop/catalyst13.11-temporary
Can you also go back to the open source drivers (in Addition Drivers), reboot, and post the output from:
lsudo lshw -C display
« Last Edit: December 12, 2013, 10:17:07 am by Mark Greaves (PCNetSpec) »
Offline skronk
« Reply #69 on: December 10, 2013, 08:56:54 pm »
Wifes friend has popped in.
True joy !
Will try in the morning.
« Reply #70 on: December 11, 2013, 02:33:18 am »
No problem .. whenever you're ready :)
True joy !
You've gotta love sarcasm :)
Offline skronk
« Reply #71 on: December 11, 2013, 10:11:33 pm »
Hi,
Sorry computer not working too well today and other lappy is windows !
Tried first command and get this...is it correct ? It appears not to find anything !
[email protected]:~$ sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases ia32-libs-multiarch i386 libunzip amd-catalyst-13.11-beta-v9.4-linux-x86.x86_64.run.zip32gcc1 libc6-i386
[sudo] password for tony:
Reading package lists... Done
Building dependency tree
E: Unable to locate package i386
E: Unable to locate package libunzip
E: Unable to locate package amd-catalyst-13.11-beta-v9.4-linux-x86.x86_64.run.zip32gcc1
E: Couldn't find any package by regex 'amd-catalyst-13.11-beta-v9.4-linux-x86.x86_64.run.zip32gcc1'
« Reply #72 on: December 11, 2013, 11:29:45 pm »
My apologies .. dunno what happened there, a copy/paste seems to ahve picked up some spurious entries.
First command fixed above .. so try again :)
Offline skronk
« Reply #73 on: December 12, 2013, 09:45:43 am »
Cant download file you suggest
http://support.amd.com/en-us/download/incomplete
« Reply #74 on: December 12, 2013, 10:21:42 am »
You'll have to go here:
http://support.amd.com/en-us/kb-articles/Pages/Latest-LINUX-Beta-Driver.aspx
and click the link .. for some reason you can't copy/paste that link and it still work  ::)
