Author Topic: (SOLVED) Re: missing thunderbird mail  (Read 1671 times)
Offline donwatson
  • Getting older
« on: December 15, 2013, 10:43:16 pm »
I switched on this evening and when I opened Thunderbird Mail the welcome screen followed the cursor and I think there was some notification on the bottom of the screen saying screen 2, screen 3 etc.
Since losing the top of my finger I sometimes click the Left and Right buttons at the same time and I may have upset something.
When I try to get the Thunderbird to open, the red drive light comes on but goes out again without starting Thunderbird.
How can I get the mail programme back again ?
take care
Don W
« Last Edit: December 15, 2013, 11:22:08 pm by donwatson »
Novatech build
External 2TiB HD
« Reply #1 on: December 15, 2013, 10:55:36 pm »
Are you sure you haven't just switched workspace .. and thunderbird isn't opening on the other workspace ?
Is there any output from:
ps aux | grep [t]hunderbird
« Last Edit: December 16, 2013, 12:53:34 am by Mark Greaves (PCNetSpec) »
Offline donwatson
  • Getting older
« Reply #2 on: December 15, 2013, 11:04:39 pm »
[email protected] ~ $ ps aux | grep (t)underbird
bash: syntax error near unexpected token `('
[email protected] ~ $ ps aux | grep [t]underbird
Mark,
This is what I have
I used the wrong brackets first time, but I don't get any messages
Don
Novatech build
External 2TiB HD
Offline donwatson
  • Getting older
« Reply #3 on: December 15, 2013, 11:21:19 pm »
OOOOOOOOOOOOOps
Sorry about that Mark.
I seem to have clicked on the middle mouse button and shifted the page?.
I now have everything back to normal thanks.
I looked at  the forum on Peppermint OS and asked for 'user workspace'
take care
Don W
Novatech build
External 2TiB HD
Re: (SOLVED) Re: missing thunderbird mail
« Reply #4 on: December 16, 2013, 01:23:58 am »
No problem, we've all done it .. I know I have.
You can also change workspace with
Ctrl+Alt+Right Arrow
and/or
Ctrl+Alt+Left Arrow
Ctrl+F1  =  Workspace 1
Ctrl+F2  =  Workspace 2
etc.
Unless you've removed it I thought there was also a workspace switcher on the bottom panel of Peppermint 3
« Last Edit: December 16, 2013, 01:26:43 am by Mark Greaves (PCNetSpec) »
