Author Topic: Transferring video clips to disc((SOLVED)  (Read 2109 times)
Offline Degsy
  • Sr. Member
« on: December 28, 2013, 11:36:11 am »
Hi Everyone,
I would be interested in suggestions for a SIMPLE programme to transfer and edit holiday clips to DVD/CD, nothing too fancy, just stringing the clips together and maybe adding titles etc.
I want to do this on my desktop running Ubuntu 12.04, your comments and suggestions for this would be appreciated, as I said simplicity is preferred to something "all singing,all dancing".
Many thanks,
Degsy
« Last Edit: December 31, 2013, 01:51:49 pm by Degsy »
Emegra
  • Guest
Re: Transferring video clips to disc
« Reply #1 on: December 28, 2013, 12:02:43 pm »
Hi Degsy
Openshot
You should find it in synaptic or you could add the PPA to get the latest version and updates
sudo add-apt-repository ppa:openshot.developers/ppa
sudo apt-get install openshot openshot-doc
It's a great and easy to use program and it's in active development, I've used it to make family video and I can't recommend it highly enough
Here's a link to the developer website
http://www.openshot.org/
Good luck
Offline Degsy
  • Sr. Member
« Reply #2 on: December 28, 2013, 12:19:54 pm »
Thanks Graeme, already had that downloaded, so will give it a go, looks to have a clear starting page. As I said I am not looking to do anything fancy or professional, just burn a few home movies to DVD.
Cheers,
Derek
Offline Degsy
  • Sr. Member
« Reply #3 on: December 31, 2013, 10:07:36 am »
Hi Graeme,
Just thought I would add a quick update, used Openshot for my first short clip of video, very straightforward, looking forward to getting on now with the backlog.
Once again thanks for your helpful suggestion.
Degsy
« Reply #4 on: December 31, 2013, 12:01:19 pm »
Can you please remember to mark this topic (SOLVED) if you consider it so.
TIA :)
Offline Degsy
  • Sr. Member
Re: Transferring video clips to disc((SOLVED)
« Reply #5 on: December 31, 2013, 01:53:19 pm »
Done as requested.
Degsy
Emegra
  • Guest
« Reply #6 on: December 31, 2013, 01:59:56 pm »
You're welcome, glad to to be some help,
I think openshot is one of the best open source projects around just now and it's just gonna get better
Happy New year when it arrives
« Reply #7 on: December 31, 2013, 02:02:39 pm »
Thanks Degsy :)
