Author Topic: Subject: No Wireless connection Fedora 20 (SOLVED)  (Read 39235 times)
Offline chrifmarwen
« on: January 04, 2014, 09:55:49 pm »
Hello,
I have recently installed , Fedora 20 Os in my PC but the Wireless don't work .
Can anyone help me to fix this ?
Thank you.
« Last Edit: January 18, 2014, 03:15:36 pm by chrifmarwen »
Re: No Wireless connection Fedora 20
« Reply #1 on: January 04, 2014, 10:04:55 pm »
Open a terminal and post the output from running these commands:
lshw -C network
lspci -vnn | grep net
lsusb
Offline chrifmarwen
« Reply #2 on: January 04, 2014, 11:31:10 pm »
[root@localhost chrifmarwen]# lshw -C network
bash: lshw: unknown comand...
[root@localhost chrifmarwen]# lspci -vnn | grep net
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM57785 Gigabit Ethernet PCIe [14e4:16b5] (rev 10)
[root@localhost chrifmarwen]# lsub
bash: lsub: unknown comand...
« Reply #3 on: January 05, 2014, 01:16:54 am »
Is this a USB wireless adapter ?
Try
lsusb
again, as you made a typo in your last attempt ;)
Offline chrifmarwen
« Reply #4 on: January 05, 2014, 07:12:04 am »
No it's not usd wireless, it's embeded.
Wired connection work fine .
[chrifmarwen@localhost ~]$ lsusb
Bus 002 Device 003: ID 8564:1000
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0489:e010 Foxconn / Hon Hai
Bus 001 Device 003: ID 064e:d250 Suyin Corp.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
[chrifmarwen@localhost ~]$ lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation 2nd Generation Core Processor Family DRAM Controller [8086:0104] (rev 09)
Subsystem: Acer Incorporated [ALI] Device [1025:0504]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:02.0 VGA compatible controller [0300]: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0116] (rev 09) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 49
Memory at b0000000 (64-bit, non-prefetchable) [size=4M]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 2000 [size=64]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:16.0 Communication controller [0780]: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 [8086:1c3a] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 50
Memory at b0704000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
00:1a.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at b070a000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 51
Memory at b0700000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 9fb00000-9fbfffff
Prefetchable memory behind bridge: 00000000b0400000-00000000b04fffff
Kernel driver in use: pcieport
00:1c.1 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 [8086:1c12] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: b0600000-b06fffff
00:1c.3 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 [8086:1c16] (rev b4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: b0500000-b05fffff
00:1d.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at b0709000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation HM65 Express Chipset Family LPC Controller [8086:1c49] (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller [8086:1c03] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 40
I/O ports at 2088 [size=8]
I/O ports at 209c [size=4]
I/O ports at 2080 [size=8]
I/O ports at 2098 [size=4]
I/O ports at 2060 [size=32]
Memory at b0708000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller [8086:1c22] (rev 04)
Flags: medium devsel, IRQ 19
Memory at b0706000 (64-bit, non-prefetchable) [size=256]
I/O ports at 2040 [size=32]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at b0430000 (64-bit, prefetchable) [size=64K]
Memory at b0440000 (64-bit, prefetchable) [size=64K]
Expansion ROM at b0450000 [disabled] [size=2K]
Kernel driver in use: tg3
02:00.1 SD Host controller [0805]: Broadcom Corporation BCM57765/57785 SDXC/MMC Card Reader [14e4:16bc] (rev 10) (prog-if 01)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at b0400000 (64-bit, prefetchable) [size=64K]
Kernel driver in use: sdhci-pci
02:00.2 System peripheral [0880]: Broadcom Corporation BCM57765/57785 MS Card Reader [14e4:16be] (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 7
Memory at b0410000 (64-bit, prefetchable) [size=64K]
02:00.3 System peripheral [0880]: Broadcom Corporation BCM57765/57785 xD-Picture Card Reader [14e4:16bf] (rev 10)
Memory at b0420000 (64-bit, prefetchable) [size=64K]
03:00.0 Network controller [0280]: Broadcom Corporation BCM43227 802.11b/g/n [14e4:4358]
Subsystem: Foxconn International, Inc. Device [105b:e040]
Memory at b0600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: bcma-pci-bridge
05:00.0 USB controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 04) (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at b0500000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: xhci_hcd
« Last Edit: January 05, 2014, 11:13:32 am by chrifmarwen »
« Reply #5 on: January 05, 2014, 01:42:54 pm »
With an active (wired) internet connection, run:
su
yum install akmod-wl
Offline chrifmarwen
« Reply #6 on: January 05, 2014, 02:01:53 pm »
 :D it works ! Thinks !
« Reply #7 on: January 05, 2014, 03:42:21 pm »
You're welcome :)
If you now consider this issue solved, can you please edit the FIRST posting in this topic and change
Thanks in advance :)
Offline chrifmarwen
Re: Subject: No Wireless connection Fedora 20 (SOLVED)
« Reply #8 on: January 18, 2014, 03:19:49 pm »
Hello,
I've another problem after updating feedora 20,  but now the wireless led is on but no internet connection.
can anyone help me pleas ?
« Reply #9 on: January 18, 2014, 07:23:31 pm »
what's the output from:
rfkill list
Offline chrifmarwen
« Reply #10 on: January 18, 2014, 07:31:18 pm »
bash: rfkill: not known
Offline SeZo
« Reply #11 on: January 18, 2014, 07:58:43 pm »
You might need to install it:
su
yum install rfkill
Offline chrifmarwen
« Reply #12 on: January 18, 2014, 08:10:33 pm »
[root@localhost chrifmarwen]# rfkill list
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
5: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
« Reply #13 on: January 18, 2014, 10:37:41 pm »
Let's try uninstalling/reinstalling the driver again .. make sure you're connected to your router with an ethernet cable, then run:
su
yum remove akmod-wl
Offline chrifmarwen
« Reply #14 on: January 19, 2014, 07:20:07 am »
I make this done but no result : the led is off now , i tried fn + f3 to activate it but it dosn't.
