Author Topic: Subject: No Wireless connection Fedora 20 (SOLVED)  (Read 39234 times)
Re: Subject: No Wireless connection Fedora 20 (SOLVED)
« Reply #15 on: January 19, 2014, 02:19:44 pm »
now what's the output from
rfkill list
Offline chrifmarwen
« Reply #16 on: January 19, 2014, 02:56:27 pm »
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
« Reply #17 on: January 19, 2014, 04:14:06 pm »
What's the output from:
ifconfig
iwconfig
iwlist scanning
Offline chrifmarwen
« Reply #18 on: January 19, 2014, 04:36:26 pm »
[root@localhost chrifmarwen]# ifconfig
em1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:70:f4:aa:87:64  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 16
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 0  (Boucle locale)
        RX packets 936  bytes 81360 (79.4 KiB)
        TX packets 936  bytes 81360 (79.4 KiB)
[root@localhost chrifmarwen]# iwconfig
em1       no wireless extensions.
[root@localhost chrifmarwen]# iwlist scanning
em1       Interface doesn't support scanning.
« Reply #19 on: January 19, 2014, 06:16:56 pm »
install lshw:
yum install lshw
then post the output from:
lshw -C network
Offline chrifmarwen
« Reply #20 on: January 19, 2014, 06:30:03 pm »
[root@localhost chrifmarwen]# lshw -C network
  *-network
       product: NetLink BCM57785 Gigabit Ethernet PCIe
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: em1
       version: 10
       serial: b8:70:f4:aa:87:64
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: pm msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.133 duplex=full firmware=sb ip=192.168.1.13 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:16 memory:b0430000-b043ffff memory:b0440000-b044ffff memory:b0450000-b04507ff
  *-network UNCLAIMED
       product: BCM43227 802.11b/g/n
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 00
       width: 64 bits
       configuration: latency=0
       resources: memory:b0600000-b0603fff
« Reply #21 on: January 19, 2014, 07:26:48 pm »
what happens if you run:
modprobe wl
does wireless spring to life ?
if not, what (if anything) was returned in the terminal ?
and what is the output from:
lshw -C network
again ?
Offline chrifmarwen
« Reply #22 on: January 19, 2014, 07:32:12 pm »
Fatal ERROR.
[root@localhost chrifmarwen]# modprobe wl
modprobe: FATAL: Module wl not found.
  *-network
       physical id: 0
       logical name: em1
       version: 10
       capacity: 1Gbit/s
       width: 64 bits
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.133 duplex=full firmware=sb ip=192.168.1.4 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
  *-network UNCLAIMED
       physical id: 0
       version: 00
       width: 64 bits
« Reply #23 on: January 19, 2014, 07:39:29 pm »
OK, what is returned if you run:
su
yum install akmod-wl
Offline chrifmarwen
« Reply #24 on: January 19, 2014, 07:51:42 pm »
Nothing to do, already installed .
« Reply #25 on: January 19, 2014, 07:55:17 pm »
OK, let's try a different method...
run:
su
yum install broadcom-wl
then if necessary reboot.
If wireless doesn't spring to life, what's te output from:
modprobe wl
now ?
Offline chrifmarwen
« Reply #26 on: January 19, 2014, 08:26:44 pm »
ALready installed and the same Error ( FATAL).
i think i shouldn't updated my os !
« Reply #27 on: January 19, 2014, 09:05:28 pm »
OK, try removing both:
su
yum remove akmod-wl
yum remove broadcom-wl
yum update -y
then REBOOT
then run:
su
yum install akmod-wl "kernel-devel-uname-r == $(uname -r)"
yum update -y
then REBOOT again.
Any difference ?
Offline chrifmarwen
« Reply #28 on: January 20, 2014, 05:53:28 am »
Mark, the problem persit ! ( Fedora suggesting me to update another time ! proposing kmod)
« Reply #29 on: January 20, 2014, 02:46:18 pm »
Give it a shot then ;)
Do a full system update, reboot, then try installing kmod-wl
