Author Topic: Subject: No Wireless connection Fedora 20 (SOLVED)  (Read 39237 times)
Offline chrifmarwen
Re: Subject: No Wireless connection Fedora 20 (SOLVED)
« Reply #30 on: January 20, 2014, 03:04:17 pm »
It worked ! Finally ,  Think you mark !
« Reply #31 on: January 20, 2014, 07:00:44 pm »
No problem :)
Offline aks007
Re: No Wireless connection Fedora 20
« Reply #32 on: September 13, 2014, 10:27:09 am »
Open a terminal and post the output from running these commands:
lshw -C network
lspci -vnn | grep net
lsusb
I have same issue.
Today I install fedora 20 and wifi is not working while LAN is working properly.
Can anybody help?
Also I have tried below options but problem is same yet.
« Reply #33 on: September 13, 2014, 01:05:55 pm »
OK, running:
su
yum remove akmod-wl
yum remove broadcom-wl
yum update -y
then REBOOT
then run:
su
yum install "kernel-devel-uname-r == $(uname -r)" kmod-wl
yum update -y
then REBOOT again.
Offline Neked
« Reply #34 on: November 09, 2015, 10:38:59 pm »
OK, running:
su
yum remove akmod-wl
yum update -y
then REBOOT
then run:
su
yum update -y
then REBOOT again.
Helped me, THX a lot :) !!!
« Reply #35 on: November 09, 2015, 10:41:46 pm »
You're most welcome, glad it helped .. and welcome to the forum :)
